Engine management light on!!!
martyboy
Scotland
Website
www.bebo.com
hi, my engine light has came on today, so gave it a scan with vag-com and this is what has come up.
can anyone tell me where the "intake manifold flap" is an how much this is likely to cost to repair?
thanks
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC 0000SG 6337
Revision: 12345678 Serial number: AUX7Z0DDFN90RI
Coding: 0000072
Shop #: WSC 66565 257 00032
3 Faults Found:
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
P3101 - 000 - -
Freeze Frame:
RPM: 819 /min
Torque: 28.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 11000111
Torque: 132.0 Nm
Torque: 0.0 Nm
17075 - Fan 1 Control Circuit: Short to GND
P0691 - 000 - -
Freeze Frame:
RPM: 798 /min
Torque: 28.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 11000111
Temperature: 75.6°C
Duty Cycle: 9.6 %
19558 - Motor for Intake Manifold Flap (V157): No Signal
P3102 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 354.0 Nm
Hi Marty,
I think it will be one of the fuses has blown.
I think the fuse for the IMF and the Fan is the same, and is found on top of the battery.
What caused it to blow is another thing!
aye mate, fuse has blown.
fault cleared, fuse replaced, switched on engine, light came back on after 5 mins!!!
do you think it might have anything to do with this cold spell?
flap frozen solid, or something similar???
Marty,
It could be a frozen flap. But I'd be surprised, I'm sure VW spent millions cold weather testing - but then judging by all their other faults with this engine I wouldn't be too sure.
I think the flap is a reasonably common faulty component.
It might be worth determining whether its the flap our the fan causing the fuse to blow. Try unplugging the flap, replacing the fuse and see if the fuse blows again. The flap is only used to stop the engine when you key off or if the engine runs away with itself, so the engine should run OK with it disconnected (but you will still get the fault code).
I think you may have to replace the flap unit (I think I read somewhere that GSF or EuroCarParts can source these?).
Good Luck
