Spark plugs??
gnic13
Audi S3 8V
Aberdeen
Hi
I am running a stnd S3 8P and i am wanting to change out the spark-plugs but keep gettin conflicting opinions of what to fit!!
Any views on the better plugs to go with ?!
if it's a standard S3 use the standard plugs, cannot see any advantage in anything other. I use Bosch F5DP0R in mine as it is remapped
Use NGK Iridium plugs - there are loads of threads on here about the benefits they bring. Search around a bit.
Denso Iridium VK20Y, vagtech recommended, installed on many TTS's. told no need to alter gap even with remap.
Still running the standard plugs here,with Stage 2+,and no problems.
We did try the Iridiums in an effort to cure a misfire,but the solution was another problem altogether!
10
9
632
710
