Adaption with VAG-COM
metricspaces
Would anyone have details on how to carry out adaption using VAG-COM?
I understand that the ECU "learns" certain values over time, and with adaption it is possible to reset these values so that the ECU can "learn" them again.
I recently got a remap, and it was suggested that carrying out adapation with VAG-COM would be a good idea.
Ok, thanks. I'm pretty sure I heard somewhere that it can be done with VAG-COM. Anyone any info on this?
sorry its engine, then adaption, then read save.
And reading the codes and reseting them puts the ECU back into to learn mode, don't know why but it does
Byzan A4 is corrrect. clearing the fault code, even if there aren't any, will reset your fuel adaption values. You can see this by viewing block [FONT=&quot]032 = [/FONT][FONT=&quot]Fuel adaption values, it will read zero once you do the "clear codes".
[/FONT]
You can read codes no problems without resetting anything so do not worry about that. It's a little known feature
577
457
