I know there is much debate about the reliability of VAG coil packs but my latest problem causes me concern. 2 hours after last use with no symptoms, my A3 would't start, it cranked ok and fuel could be smelt but no ignition. On investigating, there was a strong electrical burning smell coming from the engine bay in the area of the fuse box and the main feed was drawing 20 amps with the ignition in the accessory position when measured using a current clamp. The cause is a short circuited, melted coil pack which having drawn in excess of 20 amps has blown the ECU 20 amp fuse. The car is in warranty and the dealer has changed all 4 coil packs and the burnt connector on the failed coil pack loom. The tech I spoke to has saved the coil pack for audi to investgate as he has not seen one fail that catastrophically before. I've only had the car 2 weeks and covered under 200 miles, given the potential degradation to the wiring system should I be concerned?
