I had real difficulty updating mine and ended up giving up. It should have been updated by the Audi dealer before it was sold to me but this wasn't done and by the time I'd realised the free update period had ended. I did try downloading the latest maps from MyAudi and putting the file on to an SD card but it wouldn't work and the car couldn't recognise the file. I think it stops working once the car reaches a certain age unless you pay for it.Just thought i would ask what do you guys do about updates....... is it done online or do you buy sd cards.
I'm new to this and my nav system is from back when the car was built in 2019 i think.
So did you activate this yourself?mines mib2 and mine now has wirless car play
Should be done online within the audi customer portal.Just thought i would ask what do you guys do about updates....... is it done online or do you buy sd cards.
How do i get access to this please...... sorry but I'm new to this.Should be done online within the audi customer portal.
I've just tried doing this again and unfortunately it still won't work - just doesn't do anything and doesn't recognise the update file is there (even though it's been downloaded to the SD card without any issues).Log in to your MyAudi account and then go to the "Services" page (I think that is what it is called but can't check as I no longer have an Audi) and there should be a section to download map updates. Download it to your computer (roughly 24Gb so you will ideally want a fast internet connection). Once it is downloaded transfer the files and directory to an SD Card or USB Stick. You will want the file and 2 directories at the top level, not a folder that contains those 3 items. Put the SD Card or USB stick in the car, it should automatically detect it has a set of map files inserted and ask you to start the update process. If it does not start automatically go to the maintenance section within the Car tab in the MMI and select the search for SW update from there. Don't worry if it does not complete during your journey, it will stop and restart as required.
Thanks so are you saying this software does something to the car to allow the latest map update to be installed?google mibsoloution 1 need an sd card and current software version it will locate latest update software and allow download insert sd in car and it will find it don't go into engineering mode!
My car doesn't have access to live download services any longer (hence the problem with updating maps etc) but do you know if this would work for updating the maps via USB/SD downloaded from MyAudi?it will show the latest update available based on your current software version
Must admit I've tried looking into it and can't really find anything which clearly explains how it works.have a look at mib1 mate then you will know what im talking about!
