One of the most common faults with these 3.0T supercharged engine is the location of the cats, right up by each bank of engine cylinders either side of the V (apparently done so to get these engines past emission regs).. the knock-on effect being that the cores of the cats breakdown over time due to the immense heat generated by these engines, and can get blocked and cause catastrophic engine damage (google it - there's been LOADS of cases!!).
The good news is, you have options:-
- Replace like for like in the stock location, and hope the above never happens
- Replace the old cats with hi-flo sports cats in the stock location... and hope the above never happens
- Remove the stock cats, gut them of material, and refit (this is the route i went - catless V6s become raspy)
- Remove the stock cats, and fit "test pipes" such as Red Star (again - raspy)
- Remove the stock cats, and fit "test pipes", and have cats welded into the system further downstream (many remove the downpipe resonators and put the cats in their location - this will get slightly louder as you've removed some silencers)
I'm sure there's a million other ways of doing the above (and manufacturers).. but these seem to be the most popular. Clearly decat options require some special attention come MOT time.
I did mine mostly for peace of mind... cat and crank pulley failure seem to be the 2 biggies. That said, if your cat broke at the front you may have some engine movement as the mounts can fail too.. so maybe worth checking those out too at the same time.
goose
