Dan Wortho
Just recently got my 2009 2.0 tdi s line and looking at h&r 35mm lowering springs. Was wondering if anyone knows what spacers would suit the car best. This is currently what it looks like
I’m not too sure the wheels are standard s line wheels 225/40/18Depends on the current wheel spec, stock is offset 54, you may have offset 43-45 if aftermarket or other chassis wheels like a4, but 5-10mm, 10mm being hub centric is better, but if it's offset 43-45 it may rub, 54 with 10mm should be ok, test & see.
Go for 10mms at most but as mentioned above check your offsets and ride height as my s3 is on 25mm H&R with 15mm all round and i rub on a speed hump at anything above 8mph lol otherwise all good bare in i need have more then 1 passenger in the car tooDepends on the current wheel spec, stock is offset 54, you may have offset 43-45 if aftermarket or other chassis wheels like a4, but 5-10mm, 10mm being hub centric is better, but if it's offset 43-45 it may rub, 54 with 10mm should be ok, test & see.
I know the wheels are 225/40/18 but not sure on offsetAre you able to get the offset, width and size of the wheels?
Damian @ DPM Performance
57.1mm I thinkI know the wheels are 225/40/18 but not sure on offset
