Tech Question - Boost
A4Andy
Quattro-tastic. Not half.
Glasgow - Southside
If I'm showing a steady 15PSI at the manifold via a boost gauge, where the ******* can my boost be leaking from?! When I accelerate while in turbo country, above 2.2k or whatever, I get a sound like an air compressor blowing; I mean it's ******* loud.
Along with this comes retardation of performance, the car isn't anywhere near as rapid as it should be having been mapped. Forge 007 fitted 10K ago as well.
So, before I trade her to some salesman that deserves all the misery that I can bestow up him, do anyone have any last ditch ideas?
Mine did this a while back, It sounded like a Hoover when I fling'd my foot down.
Mine was the 6inch Vac pipe on top of the engine. Ill get some pics up to show you when I can take a shot
Also I noticed my Main turbo pipe that runs into it was very loose when I checked.
You will need to check all your boost pipes,big intercooler ones and the vacuum ones for loose connections or splits.
Check your diverter valve first though.
It's showing 15 PSI at the manifold, after peaking at 18 PSI. The pressure is steady. After the manifold it's straight into the cylinders is it not?
So where can it be escaping?
a small leak would not be noticeable with your hearing
if its a big leak and its loud then id check the large pipes
especially the large one entering the turbo itself from the maf sensor
after this check the intercooler pipes make sure there tight and no spilts in them
Yes I lost performance big style. I only found mine by chance.
It sounds similar to mine, Il try and get pics once I get away from work.
Get someone with Vag-Com to check the Block 032 values. That will tell you if there is a boost leak or not.
Top tip, cheers.
What I don't understand is where it can be going. If full boost is available and showing at the manifold, where can it be escaping? Surely it goes straight from the manifold into the cylinder?
A4Andy said:
Top tip, cheers.
the turbo is just working a lot harder to supply the correct amount of boost.. I would get checking all hoses before driving too much harder, you will end up wrecking your turbo
If pressure is steady at 15 PSI, what pipes exist between the manifold and the cyclinders? :meeting:
There isnt any,i think what people are saying is,have you measured boost at the turbo to make sure its not producing say 18 psi and your leaking 3 psi before it gets to the manifold.
No, the turbo should be producing 15 PSI, peaking at 18 PSI. Also, if there was a leak before the manifold the preasure wouldn't be constant, it would fluctuated, the gauge is solid on 15.
481
655
393
680
