Hey guys,
I've got this A3 1.8T AGU as a project car. I know that it would've been better to get something equipped with ME7.5 instead but.. it is what it is
The problems I'm having with it are:
Until now I've discovered that the following has been replaced/fitted:
- Doesn't boost enough (goes up to 0.1bar)
- RPMs are not stable at idle (it bounces between 900 and 1000rpm)
- Doesn't start from the first time when there is less fuel in the tank (once the fuel lamp comes on)
- I believe it is fitted with a AUM turbo (JPG 1117400800, which according to the catalog fits as a replacement for 06A145713F)
- Silicone TIP
- Vac lines replaced with silicone ones.
- Forge 007p
- Boost gauge
- VCDS scan (showed no errors)
- MAF measures 2.36 g/s at idle
- Lambda reg value shifting between positive and negative (-7.0% to 7.0%) at idle
- N75 shows 99% duty cycle at full throttle
- Inspected the TB (didn't need a cleanup)
- TB adaptation
- Cleaned the MAF sensor (no difference)
- Have checked the vac lines for leaks (no bad lines)
- Tested the FPR (holds vacuum)
- Measured the fuel pressure (2.4bar at idle)
- Tested N75 (works properly)
- Wastegate seems to sit closed
- Couldn't find any other leaks
- Measured all 4 injectors with a multimeter (12.4 ohm)
- 2 of the injector inserts looked "oily" so I ordered 4 new ones, but I don't think that could be the cause.
