Yes disable the egr , so simple , with engine off remove egr ( metal hat ) vac line and plug with bolt the vac line , this disables the egr and it remains closed .
Enjoy the earlier turbo spool as all the exhaust gasses are used to spool it .
And engine oil cleaner for longer , if you suck out the oil cooler below the oil filter housing . Topside vacuume oil extraction is King and easy .
There's no black oil in both my dervs .
Blank is optional and will stop the egr feed tube from filling the egr feed tube.
A slip in 1.5mm blank is ideal and is invisible for MOT .
Make sure the engine top cover rubber is present and covering the egr metal actuator hat for mot .
Eml doesn't cause limp mode or poor running but is mot failure so some software adjustment is required .
Older B6 haven't the egr monitored by the ecu.
Thermostat is crucial on these , new housing and do CTS whilst drained down too , all cheap parts .
Then there's the famous Mr Muscle VNT turbo cleaning method !
Oil - 507.00 is the 'stronger', longer lasting , higher quality one .
Nothing wrong with cheaper non approved 'meets or exceeds the requirements of...' oil specs are stringent in this country will definitely be American standards ACEA and API and if things are not what they should be we have VLS .
I've used lots of Tetrosyl produced 507.00 , they make for ECP and their Triple QX , G Force , Carlube Triple R , and the major supermarkets so we are talking very high volume . Asda has given me some bargain oil when the manager has had a bump on the head.
Change oil & filter every 6 months , it's cheap , camshaft kit , not as..
