The cluster was fully compatible, checked the system, it's the E version as in kmh & diesel.
The code references a system coded for but not connected or seen by the abs controller imho given it says implausible signal which means something isn't connected, something wasn't right with coding of the cluster or abs module.
I have the same abs module with tpms coded as 0006790, white dis cluster, previously red, works fine.
Be intrigued to of seen adaption channels for clusters & abs modules to compare, too late now but the fact the system worked before & updated just to dis which has been done many times before, stands to reason it wasn't a faulty part imho.
