stevey83
Hi. First post!
I recently bought a 2002 A4 B6 cabriolet which had cheap looking aftermarket headlights fitted, and my DIS also displaying headlight level fault. I’ve scanned with VCDS but not getting a connection to the control module.
I’m not sure if the headlight level controllers are in these cheap headlight units, but I’ve bought a set of halogen OEM units off eBay. Have I made a mistake? I’m not sure when I connect these up are the standard headlight levels going to work correctly with the car? It must have originally had Xenons. Or does it just need recoding to halogen?
Ideally what I would like is to fit xenons at a later date, but would like to sort out the fault. I’ve removed the fuse as a temporary measure to stop the DIS showing the fault.
Thanks Steve
Thanks Steve
