86kotek
Hi all, this is my first post in here i couldnt get answers anywhere else maybe you guys can help.
A3 8p 2004 BKD
Aircon stopped working alltogether (wasnt great but worked) got few fuses blown, v71 flap and throttle flap all gone at the same time.
I fixed all but no luck with aircon, regassed it but no joy. took it to garage (local joe) but they had no idea whats wrong either and i was told its most likely the compressor. Since the car is old i want to do it on my own and have to be sure it is the compressor.
There is no sign of clutch engaging or disengaging when pressing econ button. Nothing happens.
Whats interesting is so many fails at the same time i only noticed because windows seemed to steam up in wet weather so figured there is something wrong
No fault codes in vcds, i set low temp and auto mode and drove couple hundred miles to record a fault but none there.
When im doing hvac output tests the coolant fan is not kicking in when prompted but when i go to next test (coolant fan control module j293) both fans spin really fast, slow down and then repeat the procedure.
I hope somebody of you can shed a little light on this, thanks in advance
A3 8p 2004 BKD
