Camshaft over adjustment - long term
Ted Lindsay
Age
24
Surrey
Hello, so the other day, I found that my car was throwing up the DTC P0011. So my thoughts were that I had to change my chain link kit, so I bought a kit online.
And unfortunately the bolt which connected it to the exhaust cam shaft; was busted so I had to replace the cam exhaust shaft aswell.
I’ve just got it back and the CEL is still on ? With the same error: what else could it be, I thought the kit would have fixed it.
The car seems to have the same amount of power. But funnily enough the other day I did have the DTC p2149 which made my car go into limp mode, and cyldinder 1-3 misfired. Could these two be related ?
We have no idea what your car is ? why not put in your sig so its there for the future.
Sorry, I actually thought my car was on my profile. I’ll add it on now.
apart from that i would be looking at the cam shaft position sensor first.
Well its the cheapest easiest fix if that what the problem is.
Hey man, I can’t actually find the sensor do you have a diagram or know where it is ?
Google it but maybe i would look at the relay as thats easiest and cheapest.
I found the sensor under the left side timing. The thing is I found a new position sensor for £15 isn’t that the cheapest and not the fuel relay
