PRNDS not flashing - This was with before tests , so key in position 2 = no flash, engine running = no flash.
Engine off, key in position 2 and run tests. (Im guessing its pretty terminal - even though it starts and runs and selects gears okay)
So faults are
1 Fault Found:
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
004 - No Signal/Communication - Intermittent
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 123
Mileage: 207272 km
Time Indication: 0
Date: 2018.06.29
Time: 18:31:23
Freeze Frame:
Voltage: 8.80 V
1 Fault Found:
2 Faults Found:
01305 - Databus for Infotainment
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 125
Reset counter: 104
Mileage: 206061 km
Time Indication: 0
Date: 2018.06.09
Time: 13:25:59
01304 - Radio
Freeze Frame:
Fault Priority: 1
Reset counter: 104
Mileage: 206061 km
Time Indication: 0
Date: 2018.06.09
Time: 13:25:59
2 Faults Found:
00448 - Haldex Clutch Pump (V181)
014 - Defective - Intermittent
1 Fault Found:
Freeze Frame:
Mileage: 7240 km
Temperature: 62.0°C
Voltage: 13.70 V
Voltage: 13.50 V
3 Faults Found:
01134 - Alarm Horn (H12)
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
000 - -
2 Faults Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal - Intermittent
00106 - Signal Central Locking SAVE/LOCK Passenger Side
