G
gokiwi64
Guest
Been running fine , good mpg , starting every time hot or cold. Then tonight sitting in a bit of traffic idle started hunting and got worse until eventually the engine just cut out, no eml displayed. Managed to get it over to the side of the road etc etc, long story short local garage guy has vcds/vagcom (not sure if legit) run the basic scan and it came back with 7 faults (I wasn't present) here is an extract from the log.
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 CB HW: Bas isX 3
Component: MOTRONIC ME7.1.1 5604
Revision: 00000000 Serial number: AUX7Z0D1FN7077
Coding: 0000178
Shop #: WSC 06435 000 00000
VCID: 4D96B276D44A5E2952-8018
7 Faults Found:
16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 - 004 - Malfunction / Open Circuit - MIL ON
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 002 - Incor. Correl. - MIL ON
17800 - Camshaft Position Sensor Bank 2 (G163)
P1392 - 001 - Open Short to Plus - Intermittent
19598 - Oxygen (Lambda) Sensor B2 S1
P3142 - 008 - Signal Implausibly Lean - MIL ON
18847 - Oxygen (Lambda) Sensor B2 S1 Voltage too Low / Air Leakage / Sample Error
P2415 - 008 - - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - Intermittent
18025 - Glow Plug Pre-Heat Indicator (K29)
P1617 - 001 - Open or Short to Ground - Intermittent
Readiness: 0100 1001
Coding: 0000178
7 Faults Found:
