Stephen Payne
Just wondering what's involved in fitting one of these to replace the standard one. Is it a simple straight swap or is there more involved?
You try & buy the dimming wing mirror glassesmakes you want to puke how much they want for them
You sure it is a straight swap? As far as i know you need to run extra wiring for the dimming part.
Verstuurd vanaf mijn SM-G925F met Tapatalk
When you do an autoscan, do you see your dimming mirror in module 09 sub systems?If you've got auto lights / wipers then it's a straight swap if you're happy with just the internal mirror dimming and not the door ones.
I've swapped my A5 one this week and it took 5 mins following the link above. The mirror I bought off eBay was off an A4 so as long as the same age they are interchangeable
When retrofitted correctly it should be visible as sub system in 09.Not sure - I'll do a scan later and tell you
