My Well Groomed A4
@A4A4 - Interesting thoughts
Concur on the Angelwax, Reload & Autoglymn products
Talking about wheel sealants, my recommend is Planet Polish Wheel Seal & Shine
Easy to apply, decent durability, great VFM & the bottle last ages
I've been using it for the last 10 years & wouldn't use anything else
I get around 6 month durability in the winter from 3 coats, applied 20 mins apart
https://www.ebay.co.uk/itm/Wheel-Se...h=item41968bf081:g:CmMAAMXQhuVROv4I:rk:1:pf:0
DW review -
https://www.detailingworld.co.uk/forum/showthread.php?t=296878
Our Nev @q5man has also used this. The Pro Detailer he used also gave the thumbs up to this product
^what he said. Planet polish is the biz, easy to apply and lasts. And when detailer came to ceramic car earlier I the year he was impressed
Reactions: Bristle Hound and A4A4
IMG 20190205 135504
Used up all my Angelwax cleanliness prewash bottles for my winter wash routine. This has helped to breakdown all that salty road grime.
Used around 5.1 mix, found this okay for moderate flith but if I left the car longer than a 2 weeks then a top up of 250ml BH surfex HD degreaser was added to the mix.
Not bothering using it all year round.
But definitely a great buy for winter use.
Results speak for themselves.
IMG 20190205 095853 1
IMG 20190128 104200
@jassyo06 Thanks for the recommendation back in August.
Reactions: InvincibleA3 and NevMan
Av been using it as if it where going out of fashion mate lol its great stuff and good value for money
Reactions: NevMan and A4A4
Back to square one (again)
Car was filthy yesterday so did a Prewash > washed > and left it to drip dry.
Today washed it again > towel dried > QD spray finish.
Hopefully last more than a week since winter is over for a week or two.
InCollage 20190212 144209282
Reactions: Bristle Hound, NevMan and V8_Man
That is some commitment mate, mine is filthy, but hoping to give it a nice clean over weekend ahead of 2 weeks away in the sunshine
Reactions: A4A4
Still clean 'ish' after a week of use in the middle of winter!
Loving this mild weather.
Here it shines under the moon lit sky.
Moon
Reactions: Jassyo06 and Bristle Hound
Perfect weather to spend some time on the car.
Used these products.
IMG 20190221 120004
Hand washed, hand dried, hand waxed and hand buffed.
InCollage 20190224 221909498
No machine tools were harmed (I mean used) in making this post.
Reactions: Bristle Hound, V8_Man and NevMan
How is the Simonz back to black tyre shine? I'm not sure how effective it is spraying it on rather than brushing or wiping on. My AutoGlym Tyre Dressing has nearly ran out, and whilst I love the product, I've never used anything else.
Back to black is great for a quick fix and gives a good wet look- but it does not last that long. You better off sticking with the Autoglym stuff. Try the tyre gel it's getting some good feedback, I will probably go for that next.
Reactions: Kayobong
Couldn't be bothered to give the car it's usual proper wash and attention to detail.
Prewashed sprayed and left to dwell for about 10 minutes, rinsed off then lightly went over with a wash mitt, then rinsed again and left to drip dry.
This photo shows the before and after shots.
InCollage 20190311 111505706
Had a bit of motivation to quickly go over the interior since l was sheltered from the elements.
IMG 20190303 163601
Lastly cleaned the key fobs and treated them to a new Audi keyring!
IMG 20190303 163346
Reactions: Bristle Hound, Jassyo06, martin1984 and 1 other person
Tried BH auto foam today with the pump sprayer. Filled up to 5 litres with around 250ml of auto foam. Not sure how much l would need to get the best results. So went full on.
Found that 2.5 litres of this was enough to go around and coat the car, break down and losen the dirt. Note the car was not what I would call flithy since it has been fairly dry since its last wash.
InCollage 20190322 132512797
Left to dwell for around 10 minutes and rinsed off. Noticed it reacted well with the rinse. Grabbing more dust pollen and dirt. The results are very good, leaving the paintwork mostly clear of grime and prepped for the next stage.
I left it to see how it would dry. see before, during and after pictures.
InCollage 20190322 132258835
InCollage 20190322 132203039
It's looking good value for the money also. Would say you could get 40 prewashes in spring and summer and 20 in winter from 5l container.
Always been a fan of most of Bilt Hamber products and deserves a place on my detailing shelf hall of fame.
IMG 20190320 082756
Ran out of the BH claybar and double speed wax which should also be on this shelf.
Reactions: Bristle Hound, Kayobong, Taxboy and 1 other person
This arrived today.
IMG 20190325 141206
Looking forward to try this polish. Car not been DA polished for nearly 6 months now.
Reactions: NevMan and Jassyo06
6 months since its last machine polish. So time for a spring clean.
Managed to get the car polished using the sonax profiline perfect finish and finished off with poor boys natty blue paste.
IMG 20190327 134608
The sonax polish went on great, no splash or dusting, little went along way and it buffed off very easily.
Not to sure about the natty blue. I think my tub may have been dodgy. When I used a knife to spread it on the pad it seemed dry and chalky when spreading. Carried on regardless and the wax buffed up good enough.
Here is the finished results
IMG 20190327 133022
I'm happy with it.
Reactions: RossN14, NevMan, Bristle Hound and 3 others
Post polish pics, couple of weeks in and loving the way daytona looks in different lighting conditions.
IMG 20190413 070210
Reactions: InvincibleA3, Kayobong, josul and 2 others
One of those jobs been putting off for a long while now.
Removing the old wheel balancing foam pads off the alloys.
Bit of tar remover and plenty of rubbing later.
InCollage 20190416 174125499
Reactions: josul, NevMan, Scotty75 and 2 others
Since removal off those leftover foam balancing pads on all the alloys. It was ready to clean and seal the wheels.. Alloys prepped with BH auto wheel and some tar remover to remove some stubborn black spots which were missed previously.
Then it was ready to try the planet polish wheel & shine.
IMG 20190418 125053
Not forgetting to pull off the bolt caps and give then a clean also. These were filthy.
InCollage 20190418 170818504
3 coats of sealant later. Much later..
IMG 20190418 132104
All done!
IMG 20190418 135838
IMG 20190418 170344
See how it performs now..
Reactions: josul, NevMan, Bristle Hound and 2 others
Wheels look amazing but l couldn't be ***** applying coats and coats of wheel Sealant to wheels, rather take em off and apply a ceramic on them mate, but great job
Reactions: A4A4 and Scotty75
All done!
Top work as always @A4A4, I have used PP myself, but alloys now coated with GTechniq C5 which is performing very well so far
Reactions: A4A4
All done!
@A4A4 - What do you think of the Planet Polish WS&S then buddy?
Easy enough to apply?
How much did you use in the end?
Happy with the finish?
@jassyo06 - Don't knock it till you try it mate
You just my be surprised at how good this product is
Still if you've got the time to remove each wheel one at a time, then decontaminate each wheel before application of some over priced ceramic coating & then re attach each wheel, feel free
I ain't got the time for that
Been there done that ain't doing it again
Reactions: A4A4
Wheel sealants are just that av polished/waxed my wheels numerous times whilst on the car and its a PITA, so I prefer once a year to take the wheels off and do it properly, there's also the **** easy way to seal your wheels whilst on the car with just a couple of sprays of wet coat etc etc then rinse, but a ceramic coating is defo the far superior way to coat the wheels and its only £20 for a guaranteed one years protection. .. You'll never get the same results and durability of any wheel coating whilst they are on the car physically impossible
Very, very easy to apply went on smoothly, just gave them a light dusting of Planet Polish, didn't need to use much of it, loads left. Looking to be great value for money.
Happy with the finish looks brill! even like new, not bad for alloys coming up 5 years old!
Yes, the initial 3 coats took a while but worth the effort. It now has good base protection with only need of 1 top up coat once every month.
That's the plan anyway.
See how it goes!
Reactions: NevMan and Bristle Hound
After used daily and clocked up nearly 180 miles. Thought I would see how the PP wheel seal + shine performs.
Past days conditions dry and hot.
Here is how the front alloy looks.
Swiped a dry MF cloth very lightly over the dirty alloy and the brake dust and muck came away very easily.
IMG 20190422 155444
Finished off with QD mix spray on quarter of the wheel. Left the rest until it gets a wash either by me or the heaven's. Which ever comes first..
IMG 20190422 155412
So far it seems to be really good stuff and a worthy buy.
Reactions: josul, Bristle Hound, NevMan and 2 others
Bought both of these for around £11 all in. Sonax cockpit cleaner matt effect and Sonax leather care cream. So for that price I was not expecting much, I was shocked..
IMG 20190501 142320 1
Cockpit cleaner was really good at removing dust, water spots and stains from the interior plastic trims, dash and doors. It also left a pleasant lemon smell. Went on great and left a matt finish.
IMG 20190501 162549
IMG 20190502 194936
The sonax leather care was just as good. Not too shiny on the leather and restored it back to it's former glory.
IMG 20190501 143618
IMG 20190502 203035
Not bad for £11 and loads left for many applications, fantastic find and value.
IMG 20190502 203436
These Sonax products are seriously good.
Reactions: RossN14, josul, Bristle Hound and 2 others
Looking great as always mate! I was considering giving Sonax a go, looks like I'll be ordering some of that interior cleaner tonight. I've seen it in spray bottle form, so hopefully it's just as good.
Reactions: A4A4
Looking good. Sonax seems to be one of those manufacturers whose products work well without emptying your pockets
Sent from my SM-T800 using Tapatalk
Reactions: NevMan, A4A4 and Bristle Hound
So far this year purchased.
Poor boys natty blue wax
BH auto snow foam 5 litres
Planet polish wheel seal & shine
Sonax profiline perfect finish polish
Pure definition fine grade clay bar
Edgeless MF 465 GSM cloth
Chemical guys blue hex logic pad
Kent 2in1 noodle wash mitt
500ml Autoglym bodywork shampoo and conditioner.
All this for around £100 outlay which is still a hell of a lot cheaper than someone else doing it.
Thinking about it, it would cost more than double that to get your car hand washed in one of those spit & shine places once a week.
Reactions: Jimbob76, Kayobong, V8_Man and 2 others
@A4A4 - Is that all ?
Must try harder !
Reactions: Taxboy, A4A4 and NevMan
@A4A4 - You could do with swapping the 'Kent 2in1 noodle wash mitt' for a Microfiber Madness Incredimitt IMHO
https://www.polishedbliss.co.uk/microfiber-madness-incredimitt
They may be expensive but they are a top bit of kit
I've had mine just over 5 years now & its still going strong
@jassyo06 & I don't agree on most things car Detailing (more likely he's doesn't agree with me on ANYTHING ! lol) but I think you'll find both him & I are on the same page with this mitt
Reactions: A4A4 and Jassyo06
Yup and that reminds me when l get HOME to add a new yin to my detailing product list
+1 or is that +2 on the Microfibre Madness Mitt, I have two of them, one mitt, one the smaller pad
My MMI display has lots of hair line scratches on it and some of the anti-glare coating on the screen is coming off in places.
Best way for me to tackle this is to remove the anti-glare coating fully. This will remove those hair line scratches also.
Used Plast- RX for this job.
IMG 20190515 090902
With aid from a couple of MF cloths, cotton buds, pads and masking tape.
Little worried about rubbing the polish all over the screen but once buffed off the scratches were quickly removed.
InCollage 20190515 200614936
More time was taken to remove all the coating but the end results were great.
IMG 20190515 153515
The MMI screen looks 100% better, like new. Not noticing any problems with glare either.
Worth a try if you have any scratches on your MMI display. But you have to go the whole hog and take anti-glare coating off otherwise you will have a patches on the screen.
Also used PLAST-RX to polish the front and rear lights which removed discolouring, stubborn water marks, stains and light scratches.
IMG 20190515 115119
Reactions: Bristle Hound, Kayobong, V8_Man and 1 other person
Thought it be useful to include this photo of a before and after shots.
To show better evidence of how it worked.
InCollage 20190515 153647748
Reactions: Ant L, Bristle Hound, NevMan and 1 other person
