WiseNatcho
Have only had my A3 for a week now and finally got around to plugging in a Carista ODBII Reader and scanning for errors.... Unfortunately it returned 40
Is it as bad as it looks, and any suggestions as to what may be wrong? There seem to be a lot related to voltage and power?
Thanks in advance!
Engine:
P0562 - System Voltage, Low Voltage
P1601 - Relay for Supply Voltage Terminal 30 (J317), Implausible Signal
P0300 - Random/Multiple Cylinder Misfire Detected
P0301 - Cylinder 1, Misfire Detected
ABS:
01826 - Sensor for Steering Angle (G85), Voltage Supply Terminal 30
00668 - Supply Voltage Terminal 30
Airbags:
13635840
Headlight aiming:
00446 - Function Limitation due to Under-Voltage
Instrument cluster:
00532 - Supply Voltage B+
Central electronics:
01504 - Bulb for License-Plate Light (X)
02399 - Control circuit for terminal 30 for interior illumination
00059 - Terminal 30 for Interior Lighting
02383 - Windshield wiper motor Function restricted due to under-Voltage
Body/convenience system:
01135 - Interior Monitoring Sensors
00332 - Control for tank flap
Driver's door:
01811 - Supply Voltage for Door Controller, Drivers Side (J386)
Front passenger's door:
01812 - Supply Voltage for Door Controller, Pass. Side (J387)
Steering wheel:
Heater & air conditioning:
Navigation:
00856 - Radio Antenna
00858 - Connection; Radio ZF Output to Antenna Amplifier
00878 - Connection to Speaker Front Left
00879 - Connection to Speaker Front Right
02454 - Microphone unit (in front roof module) (F164)
02005 - Coding Pin
Radio:
02005 - Coding Pin
CAN network gateway:
00470 - Combination comfort Databus in Single Wire
Thanks in advance!
Engine:
ABS:
Airbags:
13635840
Headlight aiming:
Instrument cluster:
Driver's door:
Steering wheel:
Navigation:
02005 - Coding Pin
Radio:
02005 - Coding Pin
