Hiya mate. I just went into that what you told me to. It's got steering wheel. With a tick in the box. Is that for mfsw. This hasn't got 1. And it's also not got the tick in the box for sound system. Should that be ticked for Bose
Thanks mate
This is the faults I've got left haha
The phone seems to have cleared now I changed the code. But the rnse is still there
Plate: VA07MXP
Mileage: 101030km-62777mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56
Mileage: 101030km-62777miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0050
Revision: 5BH16--- Serial number: AUX7Z0G4FNM0QO
Coding: 01030003180F0160
Shop #: WSC 66565 257 00032
VCID: 377D41BA468CAEFA51-8062
2 Faults Found:
012313 - Valve for Exhaust Flap 1 (N321)
P3019 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 100985 km
Time Indication: 0
Date: 2000.00.00
Time: 31:63:63
Freeze Frame:
RPM: 899 /min
Load: 40.4 %
Speed: 0.0 km/h
Temperature: 58.0°C
Temperature: 39.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.811 V
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 100998 km
Time Indication: 0
Date: 2017.01.27
Time: 21:36:55
Freeze Frame:
RPM: 832 /min
Load: 16.9 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 17.0°C
Voltage: 14.097 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021128
Shop #: WSC 06314 000 00000
VCID: 72EBB0AE6D6E0BD2A6-8026
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
Component: KlimavollautomatH19 0420
Revision: 080498 Serial number: 8P0820043AH
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007137474
Coding: F18E1F07A0141000470000000000000000084E175A050000000000000000
Shop #: WSC 06314 000 08192
VCID: 45813B720C60CC6AD3-8010
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 N HW: 8P0 959 655 N
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CR0G00CWG
Coding: 0071612
VCID: 4D910352D410342A1B-8018
Subsystem 1 - Serial number: 63328RB4027D33B5M
Subsystem 2 - Serial number: 63428RB4027D480AN
Subsystem 3 - Serial number: 63528RB4027D3345H
Subsystem 4 - Serial number: 63628RB4027D47F8.
Subsystem 5 - Serial number: 63747RB40282A3DDY
Subsystem 6 - Serial number: 63847RB4028298A0N
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 100969 km
Time Indication: 0
Date: 2017.01.26
Time: 16:55:35
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000042
Shop #: WSC 00861 210 82411
VCID: 78FF82860B12618298-802C
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 981 L HW: 8P0 920 981 L
Component: KOMBIINSTR. VDO H20 0630
Revision: D0H20001 Serial number: 2244G001000695
Coding: 0005428
Shop #: WSC 12345 067 57207
VCID: 41892F621848E04AEF-8014
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K075188887
Coding: E9831F0E4006020101
VCID: 306F7AA6A3E279C210-8064
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 36634CBE418657F24A-8062
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20001 Serial number: AUX7Z0G4FNM0QO
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 192 HW: 8P0 035 192
Component: RNS-E HIGH EU H50 0650
Revision: 06S Serial number: AUZBZ7D0008729
Coding: 0209711
VCID: 6CD7AED64F4ADD226C-8038
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 216
Mileage: 100985 km
Time Indication: 0
Date: 2017.01.27
Time: 17:27:18
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H02 0040
Coding: 0004656
VCID: 428B206E1D4EFB52F6-8016
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.150 H08 1901
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 F
Component: KSG H05 0070
Coding: 9980202002186D298505489AC637
VCID: 3F8D299A6EBC96BA99-806A
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
01403 - Glass-Break Sensors; Rear
011 - Open Circuit
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Component: Tuer-SG 020 0050
Coding: 0000560
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000012
VCID: 3D71539264B084AA8B-8068
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0209711
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 216
Mileage: 100985 km
Time Indication: 0
Date: 2017.01.27
Time: 17:27:18
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0070
Revision: 00H09000 Serial number: 00067824830713
Coding: 0000113
Shop #: WSC 131071 1023 2097151
VCID: 3C775E967FAA8DA2BC-8068
1 Fault Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 216
Mileage: 100973 km
Time Indication: 0
Date: 2017.01.27
Time: 06:58:24
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 K
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005142705
Coding: 0010322
Shop #: WSC 00385 210 90017
VCID: 44872676075AF562C4-8010
End-------------------------(Elapsed Time: 01:59)--------------------------
