I'm not too sure that'd throw up a fault code - not coded for Bose.
Do you have an address 56 - Radio on your scan output?
If so, can you post it please?
Tuesday,17,January,2017,20:12:58:06319
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.1.2 (x64)
Data version: 20170107 DS267.0
www.Ross-Tech.com
VIN: WAUZZZ8P98A003226 License Plate: VA07MXP
Mileage: 100760km-62609mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 76 77
VIN: WAUZZZ8P98A003226 Mileage: 100760km-62609miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Sporadic communication error 1000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0050
Revision: 5BH16--- Serial number: AUX7Z0G4FNM0QO
Coding: 01030003180F0160
Shop #: WSC 66565 257 00032
VCID: 377D3B6446552BF92A-8062
3 Faults Found:
012313 - Valve for Exhaust Flap 1 (N321)
P3019 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 98764 km
Time Indication: 0
Date: 2016.09.01
Time: 15:02:44
Freeze Frame:
RPM: 835 /min
Load: 38.8 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 39.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 11.557 V
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 98764 km
Time Indication: 0
Date: 2016.09.01
Time: 15:02:44
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021128
Shop #: WSC 06314 000 00000
VCID: 72EBCA706DB78ED1DD-8026
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
Component: KlimavollautomatH19 0420
Revision: 080498 Serial number: 8P0820043AH
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007137474
Coding: F18E1F07A0141000470000000000000000084E175A050000000000000000
Shop #: WSC 06314 000 08192
VCID: 458141AC0CB94969A8-8010
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 06314
1 Fault Found:
00975 - Heated Rear Window (Z1)
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 5
Fault Frequency: 36
Reset counter: 220
Mileage: 99190 km
Time Indication: 0
Date: 2016.10.19
Time: 20:40:00
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 N HW: 8P0 959 655 N
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CR0G00CWG
Coding: 0071612
VCID: 4D91798CD4C9B12960-8018
Subsystem 1 - Serial number: 63328RB4027D33B5M
Subsystem 2 - Serial number: 63428RB4027D480AN
Subsystem 3 - Serial number: 63528RB4027D3345H
Subsystem 4 - Serial number: 63628RB4027D47F8.
Subsystem 5 - Serial number: 63747RB40282A3DDY
Subsystem 6 - Serial number: 63847RB4028298A0N
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 98764 km
Time Indication: 0
Date: 2016.09.01
Time: 15:02:13
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000042
Shop #: WSC 00861 210 82411
VCID: 78FFF8580BCBE481E3-802C
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 981 L HW: 8P0 920 981 L
Component: KOMBIINSTR. VDO H20 0630
Revision: D0H20001 Serial number: 2244G001000695
Coding: 0005428
Shop #: WSC 12345 067 57207
VCID: 418955BC1891654994-8014
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K075188887
Coding: E9831F0E4006020101
VCID: 306F0078A33BFCC16B-8064
4 Faults Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 177
Mileage: 100477 km
Time Indication: 0
Date: 2017.01.05
Time: 07:00:14
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Mileage: 100691 km
Time Indication: 0
Date: 2017.01.15
Time: 15:03:02
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Mileage: 100691 km
Time Indication: 0
Date: 2017.01.15
Time: 15:03:02
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 100728 km
Time Indication: 0
Date: 2017.01.16
Time: 13:57:04
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 36633660415FD2F131-8062
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20001 Serial number: AUX7Z0G4FNM0QO
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 192 HW: 8P0 035 192
Component: RNS-E HIGH EU H50 0650
Revision: 06S Serial number: AUZBZ7D0008729
Coding: 0205711
VCID: 6CD7D4084F93582117-8038
5 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 205
Mileage: 100219 km
Time Indication: 0
Date: 2016.12.28
Time: 15:23:13
Freeze Frame:
Mileage: 100210 km
Count: 2812
Clock: 15:24
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 205
Mileage: 100219 km
Time Indication: 0
Date: 2016.12.28
Time: 15:23:13
00878 - Connection to Speaker Front Left
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 100691 km
Time Indication: 0
Date: 2017.01.15
Time: 14:51:36
00879 - Connection to Speaker Front Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 100691 km
Time Indication: 0
Date: 2017.01.15
Time: 14:51:36
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 88
Mileage: 98764 km
Time Indication: 0
Date: 2016.09.01
Time: 15:02:24
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H02 0040
Coding: 0004656
VCID: 428B5AB01D977E518D-8016
3 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00100 - Drivers Interior Locking Button (E308)
008 - Implausible Signal
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.150 H08 1901
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 F
Component: KSG H05 0070
Coding: 9980202002186D298505489AC637
VCID: 3F8D53446E6513B9E2-806A
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
2 Faults Found:
01403 - Glass-Break Sensors; Rear
011 - Open Circuit
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Component: Tuer-SG 020 0050
Coding: 0000560
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000012
VCID: 3D71294C646901A9F0-8068
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0205711
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 205
Mileage: 100219 km
Time Indication: 0
Date: 2016.12.28
Time: 15:23:13
Freeze Frame:
Mileage: 100210 km
Count: 2812
Clock: 15:24
02261 - Data Medium
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 3
Reset counter: 233
Mileage: 100102 km
Time Indication: 0
Date: 2016.12.22
Time: 06:50:20
Freeze Frame:
Mileage: 100660 km
Count: 1401
Clock: 10:41
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 233
Mileage: 100102 km
Time Indication: 0
Date: 2016.12.22
Time: 06:50:20
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 100691 km
Time Indication: 0
Date: 2017.01.15
Time: 14:51:36
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 195
Mileage: 100691 km
Time Indication: 0
Date: 2017.01.15
Time: 14:51:36
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0070
Revision: 00H09000 Serial number: 00067824830713
Coding: 0000113
Shop #: WSC 131071 1023 2097151
VCID: 3C7724487F7308A1C7-8068
3 Faults Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 7
Reset counter: 235
Mileage: 99554 km
Time Indication: 0
Date: 2016.12.01
Time: 06:48:43
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 98764 km
Time Indication: 0
Date: 2016.09.01
Time: 15:03:18
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 98764 km
Time Indication: 0
Date: 2016.09.01
Time: 15:03:18
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 K
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005142705
Coding: 0011422
Shop #: WSC 00385 210 90017
VCID: 44875CA807837061BF-8010
2 Faults Found:
01523 - Microphone for Telephone (R38)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 203
Mileage: 100197 km
Time Indication: 0
Date: 2016.12.27
Time: 13:11:17
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 203
Mileage: 100197 km
Time Indication: 0
Date: 2016.12.27
Time: 13:11:17
End-------------------------(Elapsed Time: 01:57)--------------------------
