Hi,
After a lot of searching found a replacement Cluster for my car,
A4 1.8t Sport 1997.
I found some on Ebay but had the wrong part numbers, even found a company that sells Audi surplus parts and
they had new clusters for sale, but none with my part number, shame.
Anyway fitted the cluster today and very pleased my DIS is finally working again after trying to fix it many times before, and before you tell me how to fix it,, its not the soldered type, or I would have done it already.
So I believe the cluster is out of a V6, its same part number, but do I need to check the code in the cluster to make sure its set for 1.8T ??? if so what is the code I need to enter?
Also did output test using old Vag-Com that I have, all works, but --- the chime is not working ??
just my luck, am I right you cannot turn it off? then it must be broken.
I have a spare dash now, so can fix if needed by soldering, but I want ask if it can be turned off.
A4 1.8t Sport 1997.
