Basils had a S3X change :D
basil brush
Chelmsford , Essex .
Hi all , I'm back !!!
Some of you may remember my "basils mild improvement thread" ? http://www.audi-sport.net/xf/threads/basils-mild-improvements-thread.189910/
Well he had to go but through lots of overtime in my new job I'm back in the 8L fold .
This time however it isn't an 8L AGU A3 it's a BAM S3
Picked it up last night and am over the moon !
Lots of OEM+ mods planned .
Interior is growing on me !!
Back soon with some updates .
Reactions: StaceyS3, S3 Hilife and Sandra
Very tidy Basil. Enjoy
Reactions: basil brush
Very nice example, another set of rims would set it off nice, enjoy.
^^ these ones are the only thing letting it down oh and bubbling on the boot release trim
Going to keep these as winter wheels and have another set refurbed either original ronals or TT/RS4 multi spokes
you certainly are gluten for punishment - how does it compare to your old A3?
Welcome back
I have a b5 v2.2 Induction Sytem for sale if you're interested?
07794873242. message me if interested
It's quite amazing the difference an 80mm tip and cone makes, add a remap to make it far more responsive.
I can't go cone !
The noise really grates on me !
Badger v3 tip , pipercross panel in original air box , maybe a miltek ? Badger Ecu wizzardness and that's about it performance wise .
"MAY" go WMI but only if I can completely hide the install ?
My main efforts will be suspension improvements e.g. Rear tie bars , poly bushes and cookbot tca inserts .
Then brakes , fancy some nice TVR calipers ( lord knows where I got that idea !)
And generally keeping it in the condition it's already in .
Lastly a double din conversion
The standard air box is good but the inlet is smaller area than the 80mm tip, almost defeating the object, whereas an open cone will be able to flow the larger volume of air the tip will be able to draw in, you can always drill extra holes in the base of the standard air box to help flow more air.
isn't Water Meth Injection the last bit you add after all the normal stage 2 mods?
Reactions: AdzA3AGU and Tj 0785
I thought it was only hybrid/ bt builds that needed wmi didn't think it was worth while on stage 1.or 2
Fair point, but is it worth the outlay on stage 1 for what gains you would see with wmi on Stage 1
So a week of night
1st thing was to start the clean up and protect .
I thought it was a nice clean example !!
1st job was to get rid of this noncence !!
Ahhhhh that's better
Carried out the relay relocation while I was in there ready for a catch can .
Haldex and diff fluids this afternoon
Reactions: IPG
On with the diff and haldex
Diff oil was mankee!
Took me a while to even find the haldex filter !!
Easy enough to remove with the correct tool ..
Which if it helps anyone locally I'll lend out for a small deposit (returnable obviously )
While I was under there I thought I'd check the usually mentioned earth strap !!
Got to say , I can't find one !!!!
Is this the remnants of it ?
Passenger side just above the drive shaft !!!
Thank you , best get myself a new earth strap then !!
That tag pictured is actually bolted to the diff casing not the haldex, I take it they earth together and not separately ?
Sorted it with the power of my works stores
Nut didn't shear either B)
Reactions: IPG and vanilla_ice
After a tip off I've discovered my local breakers have an S3 (2 miles away)
And look what it's got !!!
Double din cage a hvac controls , £10 as I removed them myself saving them labour
This is probably as close as I'm ever going to come to feeling guilty
Reactions: Roadtrain and VAG-Slag
That's a bargin! You will make money selling your singledin set up aswell
You be surprised how much the bits go for in good condition there's the hvac units with heated seat controls going for around £150 and without £50ish as long as the buttons haven't faded and the storage compartment I seen go for +£50
Or swap your good HVAC buttons onto your salvage unit
Reactions: basil brush and Tj 0785
I am so jealous I used to love poking around scrap yards looking for inspiration and taking off the bits you need yourself. You simply don't find them anymore. Health andv safety gone mad.
This lot are absolute diamonds !!
Free to wander around , they prefer you to remove bits yourself and as proved REALLY well priced
Oh and a massive VAG section .
I do feel lucky tbh
Been a bit busy at work but I'm back now
Door blades needed a little attention !
The inner white nylon part had separated , I looked into and tried a repair but wasn't 100% satisfied so nipped down to the silver one at the breakers , half bingo ?
It had a near side one but no off side
So I took the near side one off him which turned out to be a lot lighter in colour than my ones !
No matter
Look much nicer and line up , winner
And got the chance to de crud the door bottom and wayoyl it
Done
Just need an off side one now !
Reactions: IPG
you can't stick it back together? that inner white part?
I'm trying !
I've butchered the ruined passenger side one and epoxied the white nylon part into the drivers side one and will self tapper it once dried and grind the screw heads off , I have got my feelers out for a good replacement though
Anyway , dropped swmbo off at Asda and popped to my local hydraulic supplier and picked up some silicone vac hose and spring clips to replace the known dodgy OE rubbish .
Found this
So left her stranded in Asda and went to GSF for this
The dipstick plate that bolts to the inlet manifold is going to see "I've painted something" action tomorrow
12
37
3K
959
