HELP PLEASE - My Audi S3 Stronic keeps stalling. VCDS log added
amit87
Milton Keynes
Hi Guys,
Have a problem with my car today. The car is under warranty but I still have the weekend to get through (Also I prefer to think of you guys as the expert than the Audi Mechanics Who couldn’t even spot a nail in my tyre!). I also like to know roughly the issue and solution prior to taking cars to garage.
Car: MY14 Audi S3 Saloon Stronic
Anyways I have attached image of the dash warning and a VCDS scan (I don’t have VCDS but my friend was very kind to let me use his quickly).
Issue happens usually 45mins into a journey when coming to a stop. Car begins to judder under 5mph…. and between 0-3mph it seems to try to stall but Auto stop/start kicks in. When I go to pull away I get along the lines “Engine could not restart automatically, restart manually”.
When manually restarted, engine didn’t restart straight away, it seemed to struggle for few seconds longer than usual and begin to shudder again. I was in stop start traffic so this occurred a few times. After the 3rd manual restart the “oil pressure” light started flashing on the dash. After no more than 10seconds, the flashing stopped and “oil pressure” light went out. This happened 3 times and EPC also came up twice.
Once out of stop start traffic, car performed perfectly fine above 20mph. It seems a slow speeds so is it stop start related or 1st gear related?! I am not sure. VCDS scan below. I have cleared the codes but kinda of need them to come back if I want to take it to audi so will see how it goes on during the weekend. From the logs, it looks scary haha. BACK-UP CAM (Module 6C) and the Tyre Pressure monitor (ABS Module 03) errors can be ignored. The Engine errors can completely new. Thanks for taking a look.
IMG 20161028 WA0012 IMG 20161028 WA0013
Address 01: Engine (J623-CJXC) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 HW: 06K 907 425 A
Component: 2.0l R4 TFSI H09 0006
Revision: --H09---
Coding: 0A1D00322426010B2004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0218V0906259 001008
ROD: EV_ECM20TFS0218V0906259.rod
VCID: 7DFA829BEC46B2AAD7-8028
3 Faults Found:
15074 - Cylinder Disabling
P130A 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 36384 km
Date: 2016.10.28
Time: 18:06:39
Engine speed: 977.50 /min
Normed load value: 14.1 %
Vehicle speed: 0 km/h
Coolant temperature: 109 °C
Intake air temperature: 70 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.906 V
Unlearning counter according OBD: 40
Engine: operating status: IS
N_TOOTH: 1002 /min
T_AST_SAE: 682 s
TOIL: 105 °C
STATE_LS_SAE[1]: OL_ERR
FUP_H_SAE: 13330.0 kPa
FUP_EFP_MES: 5086.49 hPa
15125 - Cylinder 1
P0301 00 [032] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 36384 km
Date: 2016.10.28
Time: 17:59:39
Engine speed: 951.75 /min
Vehicle speed: 1 km/h
Coolant temperature: 108 °C
Intake air temperature: 69 °C
Voltage terminal 30: 13.945 V
N_TOOTH: 947 /min
T_AST_SAE: 262 s
TOIL: 108 °C
STATE_LS_SAE[1]: CL
FUP_H_SAE: 8670.0 kPa
FUP_EFP_MES: 5126.29 hPa
15400 - Cam Adjustment Actuator A; Cylinder 4
P11AE 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35771 km
Date: 2016.10.20
Time: 11:33:46
Engine speed: 2392.00 /min
Normed load value: 7.8 %
Vehicle speed: 101 km/h
Coolant temperature: 51 °C
Intake air temperature: 14 °C
Voltage terminal 30: 14.570 V
Unlearning counter according OBD: 13
Engine: operating status: PUC
CAM_VCP[EX_1]: 1.828 °
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 1
CTR_VVL_SWI_DC: 7
T_SWI_VVL_ACR: 30.4 ms
NR_CYL_FIRST_VVL_SWI: 2
Readiness: 0000 0000
Reactions: pburv
If it was my car mate I would not run it at all and get it transported to the dealers.....From what you have explained it sounds serious....
Reactions: amit87
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 011 R HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 4319
Revision: 05852204 Serial number: TFK01311190487
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 244C97FF2F6C2362F8-8070
12 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
21154 - Gear 2
P072D 00 [002] - Not Selectable
21155 - Gear 3
P072E 00 [002] - Not Selectable
21156 - Gear 4
P072F 00 [002] - Not Selectable
21157 - Gear 5
P073A 00 [002] - Not Selectable
21158 - Gear 6
P073B 00 [002] - Not Selectable
21159 - Gear R
P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
P174A 00 [002] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
P174E 00 [002] - Electrical malfunction
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
21207 - Pressure Control Solenoid 3
P0797 00 [002] - Short to Plus
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 633330000001FD
Coding: 31F193A254222A6C037C070041C5698CC92A54C0E08296F7024100F88608
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
VCID: 7BFE8C83F252BC9AE9-802E
1 Fault Found:
16401 - Tire Pressure Warning
C102D 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 157
Mileage: 34700 km
Date: 2016.10.05
Time: 21:52:06
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000198140
Coding: 03100004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 336E64A39A82B4DA71-8066
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: C8784FD6000000000001
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011333800808
Coding: 07041A46C24122F503804004B11807A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 131201 041 0585
Serial number: 131204003010
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22009042
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 K HW: 8V0 941 531 K
Component: E1 - LDS MQB H05 0032
Serial number: 13 08 2013 00000039
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY131561LYP
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000058173031
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231334003658
Coding: 0030150051
ASAM Dataset: EV_EPHVA18AU3700000 002019
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 3B7E4C83B2D27C9AA9-806E
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 C HW: 8V0 907 376 C
Component: DAEMPFUNGS-SG H08 0066
Serial number: 231013210
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide_002_AU37.rod
VCID: 41823E6BD03E164AF3-8014
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 014 0385
Serial number: 003MMR00K5S+
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 0004FB6F9BB4DF42BC-8054
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 000 312 13
Component: SideSensor_Df 001 0887
Serial number: 357670000006B6EC6E0B
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 000 312 13
Component: SideSensor_Pf 001 0887
Serial number: 35867000000908EC6E06
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 402 311 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502B71230BC39296
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 402 311 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502AB1220765235Y
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 401 911 13
Component: FrontSensor_D 001 6149
Serial number: 3556502C91118A36020-
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 911 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A91118A3171B2
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 911 13
Component: PedP_Sensor_P 001 6149
Serial number: 2296502A11118A31B2D2
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 8 - Part No SW: ----------- HW: 480 002 110 13
Component: PedPSensor_D2 001 0887
Serial number: I0M80000000F9310FD0I
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 9 - Part No SW: ----------- HW: 480 002 110 13
Component: PedPSensor_P2 001 0887
Serial number: I0N8000000014410FD01
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 CB HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 17101308490558
Coding: A018
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 7CFC8F9FF75CBBA2E0-8028
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 970 R HW: 8V0 920 970 R
Component: KOMBI H03 2220
Coding: 27AD180A3B8046000101EA00100000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 4B9E1C43E272CC1A19-801E
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 M
Component: GW MQB High 212 2163
Revision: -------- Serial number: 28111310800027
Coding: 030100042B085A005B0002689C0B00000001000000000000000000000000
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti_010.rod
VCID: 3F863893A6CA60BA85-806A
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 12 11 2013 C0380190
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 2483941903
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00021.09.13
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002001
ROD: EV_AllWheelContrHA1VW37X_SK12.rod
VCID: 46882D77F9103172C6-8012
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 25111306070236
Coding: 001C8E204001040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 40843B6FDB341F42FC-8014
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 356A5ABB94F6AAEA5F-8060
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 29111302091677
Coding: 001C86204C01040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 01A6000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
VCID: 75EA9ABBD476EAEA9F-8020
Address 5F: Information Electr. (J794) Labels: 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 036 A HW: 8V0 035 036
Component: MU-H-LND-EU H42 0281
Serial number: A300K0D7500560
Coding: 01730101FF0A000021111101000A00102F00024701000100DE
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_AU37.rod
VCID: 30646BAF6B948FC20C-8064
Data medium:
Subsystem 1 - Part No SW: V03 959 800 QA HW: -----------
Component: ECE 2016 --- 0134
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9DY2002WA
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 R HW: 8V0 919 614 D
Component: ControlUnit_H H64 0766
Serial number: C1000019091300010394
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1008
Address 6C: Back-up Cam. (J772) Labels: 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300012201000300
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_CamSysRearPANAAU914.rod
1 Fault Found:
10489856 - No Basic Setting
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 71
Mileage: 25285 km
Date: 2016.04.10
Time: 12:59:40
active: waiting for return message
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0008
Serial number: 130124200610
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X_VW26.rod
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q0 959 595 B HW: 5Q0 959 595 B
Component: TSG HFS 020 0025
Serial number: 06121304081216
Coding: 000C86204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 42803167D5380D52EA-8016
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 020 0025
Serial number: 06121304081215
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
Reading it further, looks like a misfire?
Also could be an issue with the mechatronic ecu?
As I have said above don't drive it or have the engine running until you know what's going on... You could be doing more harm to the engine.
The timing chain on my old 8p A3 slipped/ jumped a few teeth and that started out on the vcds as an engine misfire in cyl. 1....Don't want to scare you but this could be your issue...So get it towed to your dealer..
Reactions: DJAlix and Gordo77
Thanks for your reply. I guess what you described on your 8p could happen under load and there was times I did push it (dynamic but 500to1k revs below redline) but for a S model audi this should be more than capable on a DAILY level let alone the odd times I decide to burn some fuel (and cob webs). I think I will take it to audi as soon as possible. The problem is I've cleared the codes so unless it happens soon.... audi will assume no codes. Not sure how they'd feel about a print out of the scan i have attached.
From the scan it seems like a misfire which usually coil related.... but for my sake I hope you're wrong. Good thing is its under warranty so even if I do drive it and it buggers up... minus the headache surely audi liable as I'd expect this car to last 200k+ mile easy when scheduled services are met.
Reactions: pburv
Call Audi assist, they can probably get you to a dealer and a replacement car done today.
I wouldn't worry about redlining an S3, ever. Did it to mine everyday for 2 1/2 years & 40,000 miles with no issues.
Reactions: amit87 and pburv
I hope I am wrong also...
Let us all know what the issue is when you get it booked in at the dealer...:friends:
For warranty you will need fault codes, as they need to run through the test plan related to the fault for warranty purposes.
Reactions: pburv and amit87
Hmmmm I think I'm going to have to run it to get errors back.... as its warranty... surely if makes it worse then it's audi problem as it starts etc and drives fine at higher speeds so to a novice it would seem like a small issue?!
Reactions: pburv
I would advise you give he car to Audi and get them to drive it to try and replicate the fault codes. That way if they damage it, Their problem :)
HI guys
Update:
Been driving the car to get the error (as under warranty) and couldn't get error yet. Need some heavy traffic. On 70mph cruise control did feel couple misfires but we're brief.
Gave car to audi this morning and they said car drive fine but couldn't replicate issue or error. I did give them VCDS log but advised me to keep driving till it happens again and then immediately take it back
Reactions: pburv
Just an update... nearly 2 weeks of trouble free motoring.... and all I've done is clear codes.... it is a bit worrying. I haven't been stuck in as much traffic as I was that particular day so will keep every everyone update on if the issue returns.
Reactions: TDI-line and pburv
I"ve had this on my car too. There are a number of factors that could of happen. Mine was attributed to heat soak, low oil and hard driving causing misfires.
Cleared and never returned along with letting the car cool down (it was a hot day) and checking and filling oil back up. The cars are quite sensitive which is a good thing to detect any premature issues.
I hope it's this as I filled up at not my usual garage and the entire tank car felt lump setting off at roundabouts etc. It's had couple full tanks from my usual shell garage where all the cars in my family get filled and so far (touch wood) all good!
with any luck it might just be bad fuel
Reactions: pburv
