B8 Big brakes thread?
Lavis89
Plymouth
Website
www.facebook.com
Anyone reckon it's worth doing a stickied brakes thread for the B8? i used the guide in the 8L section quite a bit and am now thinking of looking into a bbk for my s4. I know there's a lot of options for these (rs upgrade, lambo brakes, forge, brembos, q5 brembos) but dont really know much about each option. I'm happy to look up a few kits and do some research but if someone else fancied helping to create a guide it would make things quite a bit easier, especially anyone that may have already been doing some research.
Set up something along the lines of
Kit & Cost (and link if possible)
Pros/Cons (availibility/cost of discs and pads etc, bolt on or adaptors required, increase in braking force)
Experience
Reactions: jasper.s, NL316, Chop. and 1 other person
Done a bit of digging tonight
The Q5 4 pot setup looks best bang for buck and seems to work on the A4 standard discs without a problem, dont know if they'll fit over s4 discs though, i dont really want to go with smaller discs on my setup but the info will still be useful for people with a4s
18z brembo 6 pot calipers seem to be easy to get hold of and cheap and fit relatively easy but haven't found any definitive info on what discs work with this setup yet.
Lamborghini murcielago calipers also seem relatively cheap for a remanufactured pair but haven't found any information on fitting or discs yet.
PB brakes, cheap and the kits look great but dont seem to be any tried and tested, good ebay feedback but haven't found anything on forums.
Will post some links to full aftermarket kits tomorrow, the prices will make your eyes water a bit though!
Reactions: xpoweruk
Part numbers for Q5 Brembos that use OE S4 discs
8R0615107E & 8R0615108E (front brembos 345x30 Q5 )
Reactions: rizzini7 and Lavis89
Got these just need calipers now.
Reactions: xpoweruk
Those look like the same ECS discs I have on my car. The 4 pot 345mm Q5 Brembo calipers are hard to find used as they have only recently started using them and they are not used on all the models. It would be quite easy to get some 320mm Brembo Q5 calipers second hand as they are used on a few different models. I got my calipers from Mike through the parts ordering system.
One of the problems with the B8 brake system I think is lack of brake duct cooling. You really don't need big brakes to stop the car well, the 345mm Q5 setup works well and provides a lot of stopping power. If you want to do that several times in succession though the brakes will fade.
Fitting even bigger brakes helps a bit, but on the RS cars they have ducts to provide air to the brakes.
That's why I fitted the TTRS wheel well vents and Porsche Macan brake ducts to feed some air to the brakes.
Karls 3.0 TDI build thread
Reactions: CHEZ and xpoweruk
I reckon i'll be going 345 q5 setup with 2 piece discs, i will get back to work on this thread tomorrow hopefully. Even buying the calipers and discs new, it still works out a lot cheaper than the majority of the aftermarket kits out there and should provide a nice increase in stopping power
Reactions: xpoweruk
Quite a few pad choices for the Q5 (plenty more too,but it's a start)
A.B.S. 37959
BORG & BECK BBP2382
BREMBO P85123
GIRLING 6119743
HELLA 8DB355020251
ICER 182112
KAWE 152700
MINTEX MDB3313
PAGID T2212
PORSCHE 8R0698151H
REMSA 152700
REMSA 152710
ROADHOUSE 2152700
TEXTAR 2564301
TRW GDB1974
TRISCAN 811029180
WOKING P1427300
ZIMMERMANN 256431701
I'm watching this thread with interest. Thanks for your efforts mate
The Q5 Brembo caliper pad also has the same profile as the pad used in Subaru STI and Mitsubushi EVO's. So you can get pads in almost any performance street or race compound. These pads don't have the cutouts for the brake pad wear sensors but I don't find that an issue.
You don't need to cut your existing sensors, just tie wrap them up out of the way on the strut. That's what I have done with mine.
These were the red stuff pads I fitted to my front brakes. They were cheapest ordered from car parts for less as you get 10% off the performance parts. They were around £92 for the Redstuff pads
Ferodo DS2500 or DS3000 DS2500 - FCP1334H
DS3000 - FCP1334R
http://www.ebay.co.uk/itm/FERODO-RA...BISHI-EVO-5-6-7-8-9-10-FCP1334-/310766885507?
Pretty much any Pagid, EBC, Mintex, Ferodo compound can be got that will fit these calipers.
Reactions: xpoweruk
The parts numbers for the TTRS wheel well vents are
http://etka.cc/audi/part_single/cat...821/subcategory/821050/part_id/0/lang/e#sec_8
8J0807547 and 8J0807548A are the wheel well vent spoilers
The wheel well vents 8J0821191G and 8J0821192D
All these were around £55 delivered from Mike the parts guy, obviously they were never designed to fit the car so some tweaking is required to make them fit including cutting the undertray. So it's not a 5 minute job to fit these.
Will Porsche macan 6 pots bolt on with the Porsche disc's.
Sent from my ONE A2003 using Tapatalk
Do the rs5 brakes clear the standard s4 18 wheels
I had q5/ttrs calipers and 370mm disc's on 18 wheels with my vrs before as such I believe the disk will fit it's more will caliper strike the spokes of the alloys
Just acquired some rs5 stoppers
Reactions: Lavis89, rizzini7 and xpoweruk
RS4 B8/RS5 brakes fit under these 18's with spacers (I used 10mm)
Just sold my set yesterday.
Reactions: xpoweruk
Did you sell the spacers and longer bolts as well?
Looks tasty
No, I run red stuff front and back on my car. There are many people running them on there RS3's with no issues as the factory pads are both noisy, dusty and chew up the discs.
I've been pondering over an idea,but can't seem to find the full specs of the Porsche Macan 350x34mm discs.
If anybody has the ability to get the info it would be very helpful.
below is the S4 front disc info.I would like the same info for the Macan discs please :)
90590
I may well of just stumbled upon the info
Macan fron discs http://www.buycarparts.co.uk/zimmermann/8057502
Brake Disc from ZIMMERMANN
Hub Bore Ø [mm]: 68
Bolt Hole Circle Ø 1 [mm]: 112
Weight [kg]: 12,2
Hole Arrangement / Number: 6/5
Height [mm]: 52,2
Minimum Thickness [mm]: 32
Thickness [mm]: 34
Outer Diameter [mm]: 350
S4 front discs http://www.buycarparts.co.uk/zimmermann/1738392
Hub Bore Ø [mm]: 68
Weight [kg]: 11,1
Height [mm]: 52,4
Minimum Thickness [mm]: 28
Thickness [mm]: 30
Outer Diameter [mm]: 345
Reactions: Lavis89
I've been scouring google and litteraly just found that same website and came back here to post it :p
Reactions: xpoweruk
