- Joined
- Apr 30, 2014
- Messages
- 1,267
- Reaction score
- 733
- Points
- 113
- Location
- London Town
- Website
- www.youtube.com
DRL Brightness increase
Tried mine tonight FL car. They are at 127 already. Would the FL car be set up differently??
Also tried chirp when locking and now I get fault code EV_ECM20TFS0208V0906259J (AU37) guess it does not like soething
LEDs are in! Why they're not like this from the factory is beyond me.
I'm going to do this LED mod in my car. I also can't believe Audi are turning out modern cars with 80's looking yellow lights inside.
I got myself a second hand (but immaculate) front lighting module from an 8v A3 that must've had the lighting pack installed. It only cost £25 but unfortunately my car (a 2016 plate A3 Saloon) doesn't have the the correct wiring loom to allow fitment. All but one plug in my car fit correctly. The sunroof plug/socket fit fine as do the microphone and ultrasonics. The problem is with the plug/socket that power and control the lighting function of the module. My loom has a 3 or 4 pin plug and the new module has a socket that needs a 10 pin plug by the look of it.
I was wanting to know if anyone had successfully managed to install one of these LED modules into a car that wasn't originally supplied with one?
Also, does anyone know what function these 6 or 7 extra pins have? I can only think that because the LED module has touch buttons instead of the standard on/off latching switches there is maybe the need to have more circuitry to achieve the same basic function.
Any help/advice would be greatly appreciated.
Thanks,
Jon.
Actually installing one of these for customer tomorrowPicked this lil gem up for under £50 ... can't wait to do the install! @DJAlix will be needed ️
Is that the *** or BOSE sub?
I take it you're coding it in?
I'm looking at Bose sub to fit into the standard system with an aftermarket amp but I don't want to tap into the rear channels to get the signal.
Keeps us updated Tim!
As far as I'm aware it's the *** sub. Don't think I'm gonna go down the amp route, gonna wire both the sub and centre speaker I'm getting directly into the quad lock connector that goes into the MMI.
I think the stock system MMI's built in amp can accept and power the additional 2 speakers without an amp.
The issue is you need either VCP or someone with it to proper let the MMI accept it I believe.
I'll be doing all the DIY work before taking it to yoda @DJAlix to calibrate it correctly. He's been doing a lot of them recently for peeps to great success.
I means B&O in my earlier post not Bose lol
Is this possible to put the centre speaker in and the B&O sub instead of the *** sub?
How is the system Tim?
That's not mine mate, gonna be getting mine done shortly, got sub just awaiting plugs and centre speaker ... then I'll do set up, but that's all I'll be able to show as @DJAlix will be doing what he does to get it active
Ah nice! You can get the B&O tweeters too and change them out, heard it makes a massive difference.
Have you got the part number for the sub, centre speaker and plugs by any chance?
Can the tweeters been swapped out? Is the waiting already there?
I believe so, however you need to add a capacitor. I know the B&O centre speaker is a straight swap.
Check it out post #26 by larbel http://www.audi-sport.net/xf/threads/hi-and-mid-b-o-retrofit.281328/, did you ever finish this @larbel?
Yeah spoke to him but still haven't got round to sending an e-mail to @DJAlix for some more info! Will get round to it soon.
I'm a little busy over the next couple of weeks so I've not gone to town on research yetlol
