2.0 TDI Fan issues after AMD remap 193 BHP
Arjuanamo
4300K
London
Hi,
i got my car remapped last year by AMD in essex from 140 to 193 Bhp . It was probably the best upgrade i have made on my car and noticed the difference when i drove a 140 yesterday .
The issue i am having is that i noticed on a number of occasions after a drive my fan is running really loudly for about 10 minutes . it has only been going on for the last coupe of months . My car is at 50000 miles and has had its regular oil changes including the gearbox . I had my cambelt changed last month and audi reported nothing after their regular health checks . i was wondering if this was anything to be worried about and if anyone knows why my fan is staying on after i turn the car off ?
The fan pack issue is a well known one with A3s,and my old 3.2 had exactly this.
As far as I can remember,it's down to one of the thermostats,but someone else will be along with better info soon.
The fan issues are totally separate from the map
Reactions: S3Alex
Thanks for the replies . What would cause this issue and does it have a Simple solution or any serious consequences ?
If you use the forum search facility you'll find plenty of threads.
http://www.audi-sport.net/xf/threads/fan-running-all-the-time.215550/#post-2144959
This one might help as well....
http://www.audi-sport.net/xf/threads/possible-radiator-fan-problem.59532/
It's often the fan control unit,or thermostat related,and whilst it won't cause serious problems running constantly,it may result in the battery running low.
Another cause is here....
http://www.audi-sport.net/xf/threads/radiator-staying-on-when-all-turned-off.171610/
The fan will stop on if the car is stopped when it has just finished or is in the middle of a regen on the DPF. You need to check to make sure the DPF is being regenerated correctly and you don't have a sensor issue.
If you have had the DPF deleted when it was remapped then this isn't your issue.
Reactions: S3Alex
hoped you'd be along!
