Eps error
drunknspikes3
Member
eps error popped up on the display the other day and didn't go off until I turned car off then started it again the light went off so charged the battery and put a odb code reader on it showed no codes so as I have read low or bad battery's can make the light come on so charging seem to have worked but I decided to put a good battery on it that my bro in law bought anyway because since having the car it seemed to be sluggish at starting so swamped the battery then left it over night and first time stating it the light came on again so charged the battery I put on the day before and the error still shows the if I turn car off and on again it goes
I know when you disconnect the battery the eps system shows a light until you drive the car a bit then goes off because it has to relearn or what ever but it stays on the eps system must work as it goes off if the car is restarted so I'm really stuck on how to fix this error has anyone experienced this at all my car is a 56 plate Audi s3 thanx in advance (ps hope that all makes sense )
Try full lock left, wait 15seconds , then full lock right
Reactions: drunknspikes3
Have you tried a vcds scan? ODB reader wont neccesarily show all faults
You should try read codes when steering wheel light is on :)
hi not had the vcds on it yet ive bought a brake switch for £8 apparently that brings up the eps light and i think i slammed on on the breaks and thats when the light came on I think so before i start taking it to a garage and get rinsed for money going to try that first
I would check the electrical connections first. I had this on my TDi and everyone wanted me to buy a new rack at a cool £1000.
The connections were cleaned and the problem solved.
Hi thanx for the reply what connections did your u clean ?
Reactions: Jake 61
hi thanx for the reply what connections did you clean ?
Soo my break light switch came today tried fitting it took the dash panel off and no switch ssoooo where is the break light switch on a 2007 Audi s3 8p ?
Eps plug that we tried ok Jake's car was on the rear of the subframe, it's a big ****** of a plug and a nightmare to separate, it's also fixed to the subframe which made it more difficult,
Seemed to work for a while though after cleaning.
My vcds scans came up with these codes looks like my haldex controller needs sorting
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021128
Shop #: WSC 06314 000 00000
VCID: 72EC644F6D62EEAE78-8026
1 Fault Found:
01324 - Control Module for All Wheel Drive (J492)
013 - Check DTC Memory - Intermittent
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 F
Component: Haldex 4Motion 0115
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 3068AE47A3EE9CBECE-8064
2 Faults Found:
00003 - Control Module
014 - Defective - Intermittent
02248 - Valve for Controlling Clutch Operating Angle (N373)
#1drunknspikes3, Friday at 12:45 PM
Report
+ Quote Reply
right the code eventually went away thorugh driving the car long distance must have reset the error automatically
today though when driving i had to slam on as someone didn't use indicators at the round about
turned the car off while i dropped a parcel off at a shop turned the car back on and the error codes came back so it seems to thow esp errors when i break hard anyone elese had this its been working fine for a few months ?
this code poped up today aswell
Revision: 00H13001
Coding: 0021128
VCID: 72EC644F6D62EED2A8-8026
1 Fault Found:
31
Abi
895
353
820
424
