Jiny_P said:Hi both these lights have come on and are staying on constantly in the dash display, does anyone know what the problem could be?? Thanks
I have this problem with my car too, although it's a little different. Under hard acceleration, both abs and esp lights come on, but not always and when the ignition is turned off and on they reset and don't always come back on. I also have kick back through the brake pedal from the abs even when the light is off which is a pain in the @rse!! I'm aware it could be a wheel sensor or something to do with the load sensor on the rear beam but didn't know about the longtitude sensor. Did you say that it was a factory recall??
hi im having same prob ive had on comp and upto now replaced abs pump had it recoaded but sy=till had fault i then replaced fuse box on top off batery this sorted it for about 10 minutes it came back on im now gonna try earth stap from bat to chasey dunno im thinking elecktrical foault as this happond to sum1 b4 who i knew and simler probHi both these lights have come on and are staying on constantly in the dash display, does anyone know what the problem could be?? Thanks
I took mine in for a service. Needed new battery. Esp and steering light on. Took it back to be checked, lights went out now have abs light on and an intermittent esp.
