Hi thanks, I found those too but nothing conclusive, plus I never get anything when driving, as when it starts it's totally fine, it's just that if it doesn't start straight away when pushing the key in then I know I will get the 3 beeps for the same 3 errors, and then I'm stuck for a while.
Here's my scan:
VIN: WAUZZZ8K3BA****** License Plate: *******
Mileage: 66020km-41022mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72
VIN: WAUZZZ8K3BA064437 Mileage: 66020km-41022miles
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAGA) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 022 NN HW: 03L 906 019 AL
Component: R4 2,0L EDC H29 9096
Revision: 25H29---
Coding: 12194012232403080000
Shop #: WSC 00150 219 87778
ASAM Dataset: EV_ECM20TDI03L906022NN A02011
ROD: EV_ECM20TDI03L906019AL.rod
VCID: 7EF3D950E10FD5CE0C-802A
3 Faults Found:
4695 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 65078 km
Date: 2016.02.14
Time: 19:06:52
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 65078 km
Date: 2016.02.14
Time: 19:06:52
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 65078 km
Date: 2016.02.14
Time: 19:06:52
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
Component: ESP8 front H04 0030
Revision: -------- Serial number: --------------
Coding: 160504
Shop #: WSC 06335 000 00000
VCID: 7EF3D950E90FD5CE0C-802A
2 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 5
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:33:10
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x002E
Hex Value: 0x0295
Hex Value: 0x00FF
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 7
Reset counter: 5
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:33:52
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0027
Hex Value: 0xB995
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CP HW: 8K0 907 064 CP
Component: BCM2 2.0 H04 0430
Revision: 00002001
Coding: 032200
VCID: 000FA7A893FBA33E7E-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H50 0071
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:36
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AH HW: 8T1 820 043 AH
Component: KLIMA 1 ZONE H08 0180
Revision: A1000000 Serial number: 01111020101298
Coding: 34200000
VCID: 77FDCC74C635E4864F-8022
1 Fault Found:
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:31
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000819782
Coding: 260050914034AF010001000300001D0D0F1C070806010101000000
VCID: 3C771358BF9307DE62-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 071010 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:43:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
Revision: 11001001 Serial number: 50901028501120
Coding: 100203
VCID: 489F7F88FB4B5B7EF6-801C
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:36
Freeze Frame:
Temperature: 21.0°C
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 J HW: 8K0 959 655 J
Component: AirbagVW-AU10 H41 0610
Serial number: 003GKD0L76AA
Coding: 30343435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 44876BB8CF637F1E1A-8010
Crash sensor for side airbag; driver side:
Serial number: 6334MSME580561356
Crash sensor for side airbag; front passenger side:
Serial number: 6344MSME58042E6CP
Crash sensor for side airbag; rear; driver side:
Serial number: 6352QSME17714626B
Crash sensor for side airbag; rear; passenger side:
Serial number: 6362QSME407442245
Crash sensor for front airbag; driver side:
Serial number: 63732SME48743930.
Crash sensor for front airbag; front passenger side:
Serial number: 63832SME7B743A3CE
No fault code found.
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372JJ800002
Coding: 000017
VCID: 3D711E5CA4890ED655-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 N HW: 8K0 920 930 N
Component: KOMBIINSTR. H25 0258
Revision: 00000000 Serial number: EJC32WEAA
Coding: 0F04100002000008000000
VCID: 387F0F488BAB2BFE86-806C
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:37
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G109238004
Coding: 00CF07
VCID: 0109A2AC98F1AA3671-8054
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:37
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.70 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
01312 - Powertrain Data Bus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 53
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:39
Freeze Frame:
Bin. Bits: 10000
Voltage: 11.90 V
Count: 7
Bin. Bits: 10000
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0000011456115
Coding: 011C02204100410001
VCID: 4A9B4580E547A96EE0-801E
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0135966900
Coding: 0100062020B904408120023680000000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:35
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
Component: TSG BF H12 0357
Revision: Serial number: 0000011458736
VCID: 49997A8CE041A276E9-801C
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000759455
Shop #: WSC 00000 000 00000
VCID: 34673B7897C3CF9EAA-8060
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:36
Freeze Frame:
Voltage: 11.80 V
Count: 64
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 39790A4C70A132F679-806C
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:32
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H07 0350
Revision: 00000011 Serial number: AUZ5Z6J1475895
Coding: 0500048004020500015B070000
VCID: 44876BB8C7637F1E1A-8010
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 45
Mileage: 65837 km
Time Indication: 0
Date: 2016.03.12
Time: 19:32:37
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000109201912
Coding: 010C02204000210001
VCID: 458176BCCC5946160D-8010
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000109202023
End-------------------------(Elapsed Time: 02:29)--------------------------
