Totally agree with leshkin here!You technically don't need a RR for mapping, unless you want the before and after graph. All that is required is a straight/level stretch of dual carriageway with national speed limit and ideally a roundabout at each end.
I may just go directly to Rick if this does not go ahead/finalised within the next couple of weeks - the stock DSG map is getting on my nerves
So if us southerners came to Cambridge, would it just be a custom unicorn map loaded? What about testing the map on a rolling road etc? Also would you be able to load switchable maps via the cruise control stalk?
How's the website coming along..?
My car is currently off the road having work done at amd (bad timing) misfire on cylinder 3 and a delay from the Ecu requesting boost to it being delivered and then over boosting , so I'll have to see what numbers it comes back with and how much the bill is
Rick @ unicorn can sort your tuning needs remotely.
Berwick mate, you?Love to know where you are John as I'm north east based too and going 2+ soon
Dave w
Injectors are being refurbed as we speakThat doesn't sound good, tried an injector swap?
Even if he's not there I will be, so don't worry I know how it works down to the bit level. Driver feedback as well as logs is all we need, to customise it.
Yes, but I'd have to ask Rick will get him to respond here
Bump I'll assume ric will be happy with stage 1's, B8 s4 for example.Any 5 or more Scottish bookings for next weekendd (OBD flash) will receive some discount (need to speak with Rick and he's nose deep, but lets get it rolling!!!!!!!!!!!
I'll travel most likely if there's five and a good spot. Same rules/thoughts for the southerners.
Wanna map, want it customised? Step up
Yeah come back with a report etc just waiting for amd to get back to me hopefully that will solve the misfire then it's on to the boost delay and overboostI'm assuming it includes a flow test yes?
Don't no yet amd will tell me when I pick the car up ,tbh I won't no what I'm looking at long as its running right is all I'm worried about lolWhat did the report say?
Just make sure they check the bores it's likely that you were running lean on one cylinder,Don't no yet amd will tell me when I pick the car up ,tbh I won't no what I'm looking at long as its running right is all I'm worried about lol
Cheers ,Just make sure they check the bores it's likely that you were running lean on one cylinder,
Cambridge isn't set in Stone it's a reasonable drive for me and you South Lads, I think, so it makes sense?
Yes multi-switching is available via Rick, it does depend on he car though so I'll ask him to answer.
There is no plans for a rolling road, I offered to pop down to help out we can't drag that monster with us There may be a solution if we get numbers though.
I've never had a car mapped before and thought a rolling road was needed to test the map but if not then I guess my comment is irrelevant.
If I decide to get a Stage 1 map and then at a later date decided to fit an CAI, would this cause running problems or should the Stage 1 map cope with the CAI?
