So I have been looking into exhaust bypass valves or 'Cutout Pipes' as they are also known.
This is basically the same thing as BCS use in their exhausts (They call it a power valve). For those of you who don't know, this is a valve placed somewhere on the exhaust system that can be opened via a remote and gives you the option of noise and flow when you want it and then can be closed in situations when loud exhaust noise isn't really appropriate. The advantage also being that you can control the volume of the exhaust by placing it at different points in your system, or some kits give the option to partially open the valve.
The first type is electric and then the second type is controlled by boost (BCS type). These are now installed on alot of new performance vehicles like the TTRS, they are used alot in the states and get rave reviews, however i'm lead to believe electric controlled ones aren't too reliable as the motors often fail. More primitive versions have been used on american muscle cars since the 60s!
I'm looking at having one installed on the S3 as I don't think my neighbours will appreciate me starting a full system at 5am!
So... who is running them? Do you use an electric one or a boost controlled one? (Turbo only). How does it affect your map etc?? which do you use? What are your opinions?
Here is a little info and and a few examples:
Electric: (cheaper are available)
http://www.ratsport.com/PBSCProduct.asp?ItmID=9611815
Boost Controlled: (hook up a vac pipe)
http://www.spracingonline.com/spblog/?p=131
