expat2000
Hi all
A question for the gurus!
I have a 98 A4 (b5, pre facelift) 1.9 TDI (AFN) 2WD 4 speed auto (01N).
Due to a failed CV joint the end of the RH driveshaft is looking worse for wear so I am planning on replacing it with a second hand driveshaft complete with CV joints.
According to parts base there are multiple part numbers for the driveshafts:
http://www.partsbase.org/audi/audi-a4-avant-a4-eu-1998-40720-drive-shaft-see-parts-bulletin/
8D0407272AC drive shaft with constant; velocity joints; right; tripodic; 130MM; 4-speed; automatic:; ADR,AHH,AHU,; AFY,AFN,AHL;
8D0407272DM drive shaft with constant; velocity joints; right; tripodic; 130MM; 4-speed; automatic:; ADR,AHH,AHU,; AFY,AFN,AHL;
8D0407272BE drive shaft with constant; velocity joints; right; tripodic; 130MM; 4-speed; automatic:; ADR,AHH,AHU,; AFY,AFN,AHL;
8D0407452DX drive shaft with constant; velocity joints; right; tripodic; 130MM; 4-speed; automatic:; ADR,AHH,AHU,; AFY,AFN,AHL; http://www.partsbase.org/audi/audi-a4-avant-a4-eu-1998-40720-drive-shaft-see-parts-bulletin/
So the questions are:
a) any idea of what the differences are and which one fits my car?
b) Can I use any of the 4 listed above?
b) do I need the driveshaft specifically for my engine/gearbox combo, or just the gearbox, or neither e.g. can I use one from a petrol 4 speed auto?
Most online sellers specify manual only so I presume that the auto box driveshafts differ from the manual boxes (which makes sense) but does the petrol differ from the diesel?
Any advice or hints or tips would be great.
Stuart
Stuart
