New discs / pads for 312mm setup
barkclark
Scotland
I upgraded my 288mm brakes to a used 312mm setup last year. Needing new discs and pads now though.
Anyone know what ones to get / where to get them?
I get Pagid discs from ECP as they are pre painted/preserved to stop the rust on parts the pad does not touch..........works very well
I got pagid discs and pads for the rear last year. I also noticed how they don't rust! The 312's are badly rusted! Pagid it is then!
Cheers guys!
Check out Car Parts for less http://www.carparts4less.co.uk/ they are the on line trading part of ECP . Quite often prices are cheaper with the discounts. You can put multiple orders in to get the best price depending on the cost.
Pagid discs are good, if you look in the performance part for brake pads I can recommend the EBC red stuff pads. You get 10% off with the discount code.
Karl.
Cheers for the heads up Karl! That site is a bit cheaper! I can't remember, is it the same sized pads used on the 288's & 312's? How did you find the red stuff pads for road use?
288 & 312 is the same pad .
Redcabbages are oe from cold and have a magnetic effect when hot.
And the lowest dust pad known to man .
Reactions: barkclark
Sounds good to me! Do you know if on the car parts for less website, for the red stuff pads do I need to order 2 sets of pads or does one set cover both discs?
They also have a £15 off over £100 voucher code!
I got gen discs from audi and they turn out cheaper then euro car farts
Nice! Site seems even cheaper than Euro Car Parts for some stuff which would have been my suggestion, that or eBay.
14
773
