darren t
wifes a4 2.0tdi 170 s line quattro is a bit low on power, random turbo no fault codes showing on vcds I have checked for vac leaks ect so replaced egr valve with new unit along with the inlet manifold actuator from tps improved mpg but still turbo is very very slow too respond I have cleaned maf,ran diesel purge and replaced tandem pump gasket along with diesel filter really starting too me get too me now can anyone shed some light there is no oil leaks at all on this engine no oil residue on intercooler pipes it has had a new clutch and flywheel logs and turbo and dpf levels are good regenerates normally
