An amazing tool this 90BHP 1.4 Tdi Audi A2 and I/we're still HAPPY! Love it's go-kart manners, subepr braking, around town 1st and 2nd gear acceleration; handling, and parkability.
Only issue so far is turbo overboost that results in the car going into 'limp mode'
Reason for this is that the variable vanes in the turbocharger housing are a tad coked and/or rusty and don't move as freely as they should on light throttle and so with no waste gate the system goes into fail safe.
Resolution 1) is to stop the car, turn everything off, and re-start - problem solved
Resolution 2) is to use a heavy right-foot as the issue occurs on light throttle only
Resolution 3) is to strip the turbocharger and clean the rust and carbon from the vanes.
I'm currently employing resolution 2 (and its still running @ 48mpg), and when necessary a switch off and on again as described in resolution 1.
I do find that when employing resolution 1 on the M6 at 70mph say that when relighting the motor that while the turbocharger is readily reactivated the power steering goes to sleep; but that ain't a problem for me on the M6
Best resolution is 1, stop the car, turn everything off, and re-start and then...
Hope this helps...
Hope this helps...
thank you
