- Joined
- Jan 5, 2006
- Messages
- 2,847
- Reaction score
- 188
- Points
- 63
- Location
- Somewhere in the Howardian Hills!
So I had my first long run out on the Derv Shed last night. On the quiet country roads the temp got to 90 doing around 40mph. Once I got onto the motorway this dropped to 65-75 depending on what I was following. When I arrived at my destination I turned the car off and did collected my goods then returned ten mins later.
Turned the ignition on and temp gauge showed 85 degrees. Once I started the car and drove for a few hundred metres I watched the gauge drop back down to 65 degrees.
I can't stop the viscous fan with a rolled up paper from cold so I'm assuming that's running all the time and hence faulty.
When I gave it some beans up Sutton Bank (One of the steepest in the UK allegedly) The gauge shot up to almost 90, but once I got to the top and travelled a little while it was back down to 65/70.
So is it likely to be the stat or the temp sensor? Does anyone have the correct part numbers please?
On my B6 2.5 it turned out to be the sensor.
Also this morning before setting off for work I thought I'd check the coolant level and the header tank was still under a lot of pressure. Is this normal? My B6 doesn't have any pressure when left to go cold......
Cheers.
Cheers.
