Hi,
On Friday my engine warning light came on, after running vag-com it told me that the boost control valve had an open circuit, i looked under the bonnet and the two wires that go to the connector for the control valve had broken i have since soldered the wires back (the valve i'm talking about is the one that has around 3/4 little vacum pipes going to it one of them from the top of the dump valve and sits on top of the coil packs) but the warning light still stayed on. since soldering the wires i have re installed windows on my laptop and lost the use of vag-com 311.2, (i had it working fine on windows vista but can't get it working on windows 7 so if anyone reading this also has the answer to this please share it keeps crashing when scanning) anyway i was told by disconnecting the battery for 10 minutes it will clear the fault which it did but after 2 hours the engine warning light came back on.
so my questions are does disconnecting the battery clear any faults or must i clear the faults via vag-com etc
please help as my MOT is due VERY soon and won't pass with this warning light on
Thanks,
Hardeep.
Thanks,
Hardeep.
