Hi,
I replaced my original RNS-D with an aftermarket Kenwood unit, but I have very poor radio reception. Lately I think even the RNS-D had weaker reception, but with the new HU I barely get 2 station using the auto-store function, and even the rds signal is too weak(station names appear with wrong/missing letters). I tried an adapter like this one, but made no difference... actually I got better reception without the antenna cable plugged into the adapter. I also tried removing the coaxial phantom power from the antenna cable that goes to the radio booster... in this way a got the best reception(I got 5station using the auto-store function), but still bad reception with corrupt rds inforamtion and missing radio signal while driving. With phantom power removed, connecting that adapter made no difference(that was expected). This leads me to two possible culprits: the radio amp is toasted( cracked amps on Audis seem to be common) or the cable is shorting somewhere(most likely at the antenna connection). I got the best reception by plugging in directly an aftermarket antenna, got 6 stations using auto-store with no rds info corruption.
Anyone knows where the radio antenna amplifier is located on 8Ls? I want to see if that's the problem and if it can be fixed/bypassed.
Or if anyone knows what the problem with the reception could be and I missed it? (google didn't helped me)
Thanks!
Edit: I have a 2002, 4-door, non-Bose,that came with an original RNS-D without TV/CD-Changer...it this matters
Thanks!
