I can actually narrow this down even more now, it feels pre-turbo, literally as soon as you pull away in 1st it goes then almost immediately holds back for a second then goes believe it does this 2nd n possibly 3rd n its just as you start off
Ring any bells?
Sorry did you have a full VCDS print out done?
Just did a google image search, I didnt notice the words VCDS at the top on the one he had but was more watching the numbers
There were 3 lines, something like
Fuel requested - 12.3145
Fuel given - 11.4584
Then another number at the bottom which went to 0.00 when we stopped
He said it was asking for more fuel than needed which indicated a map, and there should not be more than 1200 difference, so its like almost over fueling, i guess like carbs in the old days which would choke up then clear and go
If this makes any sense to anyone!
Thanks again mate, im learning
But, just called to book into Audi...
They won't do it as too much risk of...blowing up?! The ecu which they would then be responsible for, great![]()
NHN, thanks for the offer, I have a feeling they just don't want to get involved as feel its a
problem car :/
By the way, can they see a date remaps have been done?
Got the car back today from the place that couldnt find anything wrong...
He had tried to do something with a vacum pipe that I believe is to the left of the actuator to see if made any difference, believe it connects to tandem through inside of rocker?
Its worse, badly, and not sure if imagining it but when popped bonnet to look it felt very very hot, temp on 90 as normal but id only driven 10 minutes
When I start car it sits at 900 rpm, as soon as I drive off and come to stop it goes upto just over 1000 rpm which I could noticibly hear, it used to randomly tick over either at 900 or 1000 and had a feeling this was connected to when it ran ok and when it didnt
Make any sense or ring any bells?
I tell ya im getting pretty sick of this fookerespecially when you take it to someone and it comes away worse
interesting! this wont put any eml on or anything silly?
Cambridge mate
