Im thinking in going big turbo i got engine rebuilded (rods) 5k miles ago. atm runing k04 but thinking what would be cheaper in quality parts ofc, or just to buy gt28 manifold lines downpipe injectors? fuel pump.
The kit includes a map and its for an ME7... thats kinda the point of the kit... yes it 'can' be mapped on an AGU ECU but the ME3.8 is more fussy about hardware... and of course there is the added cost of the mapping on top of the kit... the MAF tube is not compatible with your MAF sensor either so you will have to fine a solution to that too...
The kit itself looks well presented and made but its not a massive amount of power... depends what you are chasing of course...
Should be mentioned that the kit doesn't include heat shielding that you will NEED to do... have seen far too many cars that have had BT installs and no heat shielding or heat wrapping in the appropriate places... make sure you do that bit right
