my engine is running very hot and the rad stays cold the top hose is very hot and the bottom hose is not very warm i changed the thermastate but still the same i can hear a slight ticking nose by the turbo ?
It sounds like the same symptoms as when my waterpump went, the plastic impeller breaks down. Suggest replacing waterpump with a metal impeller. Overheating damages the thermostat so you may need to replace that again at the same time.
