Im in that exact position right now and looking to find out the answer to this too.
Also just wondering is a 4bar fuel pressure regulator necessary as a lot of places say otherwise and im a bit confused on that matter at the moment??
My k04 hybrid came with a standard actuator so just wondering if this would be sufficient or if i'd have to buy a forge uprated one. Any help is much appreciated!
Have you tested the actuator? it may look 'standard' but its rating should be higher... standard actuators for K04's are 0.5bar whereas you want 0.8bar for a hybrid... CR Turbos will often supply hybrids with 1bar actuators which can a be a little high considering the spiky nature of these turbos... the actuator opening pressure can be tested or you could of course just ask the company you bought the turbo from... The Forge actuators aren't the best in their current design tbh... they tend to stick as the bush is plastic and they have very short travel...
There is quite a lot of hybrid information in this forum now so a search will get most of the info you are looking for but you do not need a 4bar FPR but you you will need 550cc injectors, rods and a custom map...
I think you've just solved a problem with my car again. I have a forge actuator and I'm sure It's still now.is there any cure for this<tuffty/>:1576291 said:Im in that exact position right now and looking to find out the answer to this too.
ahh okay. hmmm this is gonna have to be thought about properly to work this out lol. I bought this turbo off of a member on here who rebuilt the turbo and that came with a standard actuator. For now i might have to just leave it all for now and hold off until i get the rods before i put it all in.
Thanks a lot for the advice everyone![]()
