Where did you get the red lighting for the footwells from?
The lights were from ebay, someone from this forum did them before, gota say its such a cheap mod, with such a big impact at night.
Flexible LED Strip SMD Red - 10cm Piece - 12v - UK | eBay
I used 12 leds (20cm strips) for each footwell. They come with a sticky back but I found this wouldnt stick all the time and would sag or come off. It needs a 100% clean flat surface. Just pulled out the superglue again, easy fix.
For the front footwells, stuck the strips under the dash, rear footwells, under the front seats, on the frame.
I did the front and back footwells plus wiring (from the same guy) for about £8.
Easy to install, hook them up to cigarette lighter light (under console ashtray light) so they only come on when you switch your lights on. As theyre connected to this they can also be dimmed with the rest of the interior lights. As its one little strip, you can hide them well so no one can see the actual strip but only the light. Also they match the interior 100%
Love the Center dash, was it hard to take off?
Lower console has about 3 screws running along either side, under little cap covers. Also need to remove the the rear ashtray, there a couple of more screws there. If you got an armset, obviously gona have to remove that too, bolt to remove this is also accessable from the rear ashtray section. Remove the gear gaiter, the the whole unit kinda slides out but you gota put down handbrake at certain points to maneuver it out.
