Rear Mud flap Rivet??
Wozski
Guys i need a rivet/clip that fixes the bottom part of the flap to the car.
Would i be right in thinking i need this part number or is it a different part i need?
N 038 549 1 - Split rivet
where the mud flap fits to the bumper there is a rivet that holds it into place - it may, may not be that part number but im after it lol
lol i did but none look like the part thats missing on the flap
Ok mate, well its definitely not the part number you said then !
Are these mud flaps OEM extras ?
If not, then this is the only other fixing part I can find :-
N 908 214 01 which is described as 'expanding nut' size 4.8 x 19.6mm
This goes into the bodywork and an oval head panel screw no. N 910 570 01 size 5 x 16mm screws into it !
Apart from that mate then sorry 'don't know' !!!
Probably can't buy the part seperate. I know the bit you need. You push it in the hole and then hammer the middle pin in which expands the plastic holding the mudflap in place.
As the mudflaps come as a kit I suspect you would have to buy a complete set to get the said item....
Those are the ones in the second link in my post #2. As you say, you push on the 'frilly' bit and then smash the pin in to spread it !!
Just been to VW. I have to order the complete mudflap set at £36!
Back to you in the studio!!
M
26
12K
Ads
460
