All i seem to be doing lately is posting about faults on my car etc.
I have had recent problems with my engine. It all seem to of started when i fitted a carbonio. It was driving perfectly and then all of a sudden it lost power and the revs would drop down to below 500rpm and almost stall and when i press the accelerater peddle it would rev to about 1500rpm and then go no further and just keep fluctuating between 500-1500rpm.
I immediately plugged it into vag com and i got the following:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 06A 906 018 AQ
Component and/or Version: 1.8L R4/5VT MOTR HS D03
Software Coding: 04000
Work Shop Code: WSC 06435
5 Faults Found:
17967 - Throttle Valve Control part (J338): Fault in basic settings
P1559 - 35-00 - -
17973 - Throttle Actuator (J338): Lower Stop not Reached
P1565 - 35-00 - -
00670 - Throttle Position Sensor (G127)
07-10 - Signal to Low - Intermittent
16506 - Throttle Position Sensor (G69): Signal too Low
P0122 - 35-10 - - - Intermittent
01165 - Throttle Body Control Module (J338)
08-00 - Control Limit Surpassed
i cleared the codes and the first 2 still keep coming back, i was searching the net for ages and people said it was the throttle body unit itself, so i bought another one (second hand, that i was assured worked perfectly), but this one is still doing the same and i am getting the first 2 codes still.
Can somebody please help me out as this is driving me insane and i dont know if it is definately the throttle body or something else,
i have already tried the ross tech website and done everything that they have mentioned but still no luck and this includes cleaning the throttle body! i also cant do a TBA and it just says error and the volts read 0.03v and i am sure it should be about 3.3v but when i unplug the throttle position sensor it shoots upto about 5v which shouldnt be right
cheers
5 Faults Found:
P1559 - 35-00 - -
P1565 - 35-00 - -
cheers
