white smoke burning oil ?
hades-
Well-Known Member
2005 FSI T stage 3
NOT the turbo less that 100 mile been stripped all good
leakdown test all good new head cams valves etc
any ideas
TIA
DV? My mates 1.8t puffed white smoke and turned out to be faulty dv !
Sorry can't be more helpful is it down on power or anything?
Typically....
White smoke = water (head gasket failure etc)
Blue = oil
Black = fuel
no water loss
leakdown test 95%
just cant work it out
no water loss
leakdown test 95%
Did you ever find the problem with this bez? Mines doing the same. First gear, steady set off , puff of blue smoke, then fine. Little rev while stationary, small signs of blue smoke. I'm very concerned :/ left ticking over, nothing. Only noticed this after changing the pcv, do you think it could be getting any oil out of the system from the previous pcv?
yes it just stopped no idea why it did it and no idea why it stopped
blus smoke is oil tho could be oil oil but that would burn off prety quick
It's weird, it only does it every now and again, then fine. Pulls fine , drives fine, just abit concerning when ya see some smoke
496
529
13
3K
