You get 1v sensors and 5v sensors but mainly 1v on VAG cars
you get a flactuations with reading when there working right this in a graph terms is a wave with a slight flat top when sensors are working right
but this wont tell you if its a pre cat or after cat oxygen sensor
the diagnostic machine i use regular tells you which one is gone and you can also take live reading off what ever sensor you want ,
what fault codes have you had ?
16804 Catalyst System : Bank 1 : Efficiency Bellow Theshold
P0420 - 002- Lower Limit Exceeded - Intermittent
Is the code, it did turn the MIL light on for a bit but its gone off. Im just trying to determin which one it should be as if its the pre cat I can do it myself and if its post cat ill have to get someone to do it as I cant be doing with getting on ramps in this weather and crawling underneath trying to get the plastic crap off.
