part number needed
tdi-man
286mm rear solid bake discs part number needed
Rear 286 Brake Disc
1K0615601M
The dor a 310x22 Vented rear as well. Thats bigger than my fronts!! :D
P/N if any one is interested.
1K0615601N
rear discs are for an 06 Audi A3 2.0 PD140 quattro s-line.
these are fitted to my 54 plate as i uprated all my discs and callipers...
thanks
and brake pad part numbers as well please....
I can only go up to 05 plate in work.
I'd assume its the same part number.
Someone might be along soon and double check, if not i'll do it when i get home.
Hi there, can comfirm Axios's part numbers, check for 06 reg Quattro.
286x12mm discs - 1K0 615 601 M
Brake pads - 1K0 698 451 H if your vehicle has PR code 1KU
or 1K0 698 451 G if your vehicle has PR code 1KJ
Not too sure myself of the differences in the pads & don't know how much of a difference your PR code is going to be since you upgraded your discs & pads but that was the info i got off ETKA 7.
Hope this is of some help to you though.
new rear discs and pads fitted thanks for the info...
also 2 new intercooler pipes fitted ........and one on order....
much better.....
512
659
725
