19" alloy fiment
nazS3
Hi guys
can someone please confirm if 19" alloys with pcd 100 offset 35
fit straight on a stock S3 preface without spaces etc
thanks in advance:sm4:
They will fit on if they are 8" wide, for 8.5", you need ET30 to clear the front struts, there's loads of room under the rear arches, so use spacers to fill them out. ;)
Is this the same for an A3 1.8T Quattro Sport ? looking at a set of 19" wheels
Offset = ET35
PCD = 5x100
Width = 8.5J
Tyre sizes = 235/35/19
Does anyone know the answer to this or where i can find this out ?
any help would be great
OK guys just another quick question
seen another set of 19" bbs lm reps
with pcd 112
48 offset
8.5 width
will these fit straight on
& fill arches
with pcd 112
48 offset
8.5 width
& fill arches
No, they are not a direct fit, you need 5x100 stud pattern, not 5x112. You can get some 20mm 5x100 -> 5x112 hub adaptors to make the ET28, then they will fit with the correct tyres(235/35R19 would be ideal).
thanks
819
574
